Top hat change
Discussion in 'Suspension' started by Intimidator3, Apr 8, 2019.
  1. Apr 8, 2019 at 4:51 AM
    Intimidator3
    Intimidator3 [OP] Member
    Baillee
    2010 tacoma 6” pro comp stage 1 lift
    i was curious as to if you could change the top hat on tundra coilovers to fit my 2nd gen Tacoma is this possible???
    Icon_Adrian likes this.
  2. Apr 8, 2019 at 9:36 AM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    It can be done, however the upper mount is not the only difference between the 2 platforms. The 05+ Tacoma and 07+ Tundra are not compatible with one another. Shock length, spring rate, valving, bolt diameter, hiem spacers.... ect.
    Tundra to Tacoma (or vise versa) can be done on First Gen's 96-04 Tacoma's & the 02-06 Tundra with far less parts, which will explain why that may pop up as an option when searching the inter-web.
  3. Apr 8, 2019 at 10:19 AM
    Intimidator3
    Baillee
    Makes sense, thank you for the clarity I saw like you said the first gens being compatible didn’t know if it was as easy as the first gen with the second gen
