Top Hat Front Strut Replaced?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElkNut, Nov 30, 2017.
  1. Nov 30, 2017 at 3:47 PM
    ElkNut
    ElkNut [OP] Member
    Paul
    Tacoma
    3" lift
    Hey guys, does anyone know the proper name of the Top Hat that has the 3 holes & the coil spring fits into it & strut protrudes through the middle of it? I'm installing new Bilstein Struts & do not want to use the old one but I cannot seem to find them online, most likely because I do not know their actual ordering name? Thanks!
    ElkNut/Paul
  2. Nov 30, 2017 at 3:57 PM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    "Strut mount" or "upper shock mount" typically.
    PapaBear likes this.
  3. Nov 30, 2017 at 3:59 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    You can reuse the metal portion of the top hat but you should replace bushings and the main rubber coil spacer.
    BassAckwards likes this.
  4. Nov 30, 2017 at 4:13 PM
    ElkNut
    ElkNut [OP] Member
    Paul
    Tacoma
    3" lift
    Thank you! I'll check to see if there's a kit available with the bushings & rubber coil spacer!
    ElkNut/Paul
  5. Nov 30, 2017 at 4:17 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The bushing you need for between the coil and the top hat is called a coil isolator. Wheelers offroad has a pair of them for $20. Heres a link Ive been looking for a set of front shock bushings as my 5100s that i bought didnt come with any
    Tibetan Nomad, PapaBear and blu92in99 like this.
  6. Nov 30, 2017 at 4:18 PM
    blu92in99
    Elk Grove, Ca
    KYB, p/n# SM5640. About $25/ea on Amazon.
    Tibetan Nomad likes this.
  7. Nov 30, 2017 at 4:23 PM
    ElkNut
    ElkNut [OP] Member
    Paul
    Tacoma
    3" lift
    Sweet! Those are it! Thanks a ton guys!
    ElkNut/Paul
  8. Nov 30, 2017 at 4:27 PM
    Muddinfun
    Muddinfun Well-Known Member
  9. Nov 30, 2017 at 4:28 PM
    BassAckwards
  10. Nov 30, 2017 at 5:02 PM
    ElkNut
    ElkNut [OP] Member
    Paul
    Tacoma
    3" lift
    Thanks again, parts ordered!
    ElkNut/Paul
  11. Nov 30, 2017 at 5:48 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    If you order this kit from Amazon,
    It comes with the top hat, ALL the rubber bushings below and above the top hat, all the large bushing washers and the three stud nuts AND the coil spring isolators.
    How do I know this?
    Did it last week. Except I re-used the three tophat stud nuts coz they were black, instead of the supplied bright zinc.
    Old vs. new
  12. Nov 30, 2017 at 5:55 PM
    Pigpen
    Dan
    Northwest Montana
    As mentioned above, you don't want to reuse a strut mount that looks like this
    Tibetan Nomad, PapaBear and Subway4X4 like this.
  13. Nov 30, 2017 at 5:57 PM
    ElkNut
    ElkNut [OP] Member
    Paul
    Tacoma
    3" lift
    No problem guys, I ordered the complete assembly! Thanks a bunch!
    ElkNut/Paul
    Pigpen likes this.
  14. Nov 30, 2017 at 5:57 PM
    Subway4X4
    Lloyd
    NY/NJ
    Yup. When it was still all together, I could actually see the shock rod NOT centered in the top hat hole. Not good.
  15. Nov 30, 2017 at 6:00 PM
    Pigpen
    Dan
    Northwest Montana
    Same here. The shaft on the struts had a little wear, but I put them right back in - they are 5100s that are just over a year old with about 15K miles in them.
  16. May 26, 2018 at 11:26 PM
    cheeze
    cheeze New Member
    OP, did the strut mount being bored out like that make any clattering or clunking?
    I have a GX470 that uses the same KYB # number. When I swapped to 5100s, I left the old top hat on since it was damn near welded onto the perch. Now, when I go down washboards, it clatters like crazy and is driving me insane. It also kinda feels like the shock isn't damping 100%.
