Top Plate needed for '06 Double Cab 4x4?
Discussion in 'Suspension' started by Diver2255, Feb 26, 2011.
  1. Feb 26, 2011 at 9:53 PM
    Diver2255
    Diver2255 [OP] Don't be the one who sucks the worst!
    Andy
    Arkansas
    '06 TRD Off-Road 4x4 V6 SR5
    Pioneer AVIC-Z110BT In-Dash GPS/DVD, K&N Cold Air Intake, Flowmaster Delta 40 muffler, UWS Nerf Bars.
    Hey y'all,
    Ive got an 06 trd off road 4x4 v6, and Im preparing to put a 3" lift on it. The set up Im planning on running is Toytec AAL's in the rear, Bilstein 5100's all the way around, and eibach coils in the front. The question is do I need the toytec 1/2 in top plate spacers because its a double cab. Also any input on the setup is welcome. This is my dd, and I go off road every once in a while and dont get entirely crazy with it and would love not to lose all of my MPG. Thanks again.:D
    RANGERS LEAD THE WAY!
  2. Feb 26, 2011 at 9:56 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Im pretty sure you do in order to get the full 3" of lift
  3. Feb 27, 2011 at 6:33 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Matt's right, you do need the top plate spacer to get the full 3" of lift.
    And if you are using eibach coils you might have the "Taco lean" after installation. So you might actually need two of those spacers for the drivers side.
  4. Feb 27, 2011 at 8:10 AM
    Diver2255
    Andy
    Arkansas
    Cool guys, thanks for the info. Which spacer will I use for the lean, the 1/2" or the 1/4"? Also, which will give the smoothest ride, the eibachs or staying with the stock? Ive done alot of searching but most of the stuff doesnt give me any kind of info on which is best, just the different options available. Thanks again
  5. Feb 27, 2011 at 8:13 AM
    KPT
    09 Prerunner
    I have the stock coils, and I've never ridden in one with the eibachs, but from what I've heard the eibachs will give you a smoother ride.
  6. Feb 27, 2011 at 8:33 AM
    Diver2255
    Andy
    Arkansas
    How do you feel the stock coils ride KPT?
  7. Feb 27, 2011 at 8:34 AM
    KPT
    09 Prerunner
    I think they are fine but mine are only at 1.75"
  8. Feb 27, 2011 at 8:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Stacking spacers is a bad idea. What Eibach springs are you going to use? Eibach springs come in many spring rates, so we need more info before someone can simply say "Yes, you need spacers".
  9. Feb 27, 2011 at 8:42 AM
    KPT
    09 Prerunner
    How would stacking two 1/4" spacers be different than using one 1/2" spacer, assuming everything is torqued down correctly....
    I thought the eibachs only came in 1.6" lift for second gens. So people set the billys at 0.85" and get 2.45" of lift. so he would need thin spacers to get up to 3".
  10. Feb 27, 2011 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They can shift. Always use only 1 spacer. Also, The Eibachs come in a 600#, and a 620# spring rates. FWIW, The top plate spacers come in a few thicknesses. 1/4", 10mm, 15mm and 20mm.
  11. Feb 27, 2011 at 8:49 AM
    KPT
    09 Prerunner
    Which ones are the ones I always see people running on here, that provide 1.6" of lift? (without an aftermarket bumper, etc)
  12. Feb 27, 2011 at 8:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 1.6" lift ones are the 620# springs......I "think". For a while they were useing 600# springs.
  13. Feb 27, 2011 at 11:28 AM
    Diver2255
    Andy
    Arkansas
    The coils that Im looking at are the 620's. Toytec says I need the 1/2 in spacers because it is a double cab. Ive read about the taco lean, does anyone make a 3/4 spacer for the drivers side?
  14. Feb 27, 2011 at 1:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Using a 5mm on the passenger side, and a 10mm on the driver side will account for the lean.
  15. Feb 27, 2011 at 1:43 PM
    Diver2255
    Andy
    Arkansas
    Will I still have the whole 3" of lift?
  16. Feb 27, 2011 at 1:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With the 5100's set at the .85" setting, and the top plates I mentiond, Yes. You should be close.
