Top Plate Spacer Causing Ball Joint to Contact Spring
Discussion in 'ToyTec Lifts' started by DDD, Aug 3, 2011.
  1. Aug 3, 2011 at 10:24 AM
    DDD
    DDD [OP] Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I recently purchased the Toytec Top Plate Spacer Kit. It includes a 1/2 inch spacer and longer studs.
    After installing I found that the ball joint boot is contacting the coil spring when the suspension is completely extended (truck up on jacks). I have tried adjusting the LCA alignment cams but it is still contacting, also I adjusted my Light Racing UCAs in all different directions but the ball joint still contacts the spring.
    Any ideas whats going on here?
    I am using Bilstein 5100 shocks set at .85 setting and OME 885 springs. I wanted to add the Toytec spacer to get an additional 3/4" lift.
    Here are some pictures.
  2. Aug 3, 2011 at 10:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Are those OME or Eibach springs? I thought OME's were black.:confused:
    If they actually are OME 885's, put the 5100's back to 0 and let the springs to the lifting. No need to preload them and use a top plate spacer.
  3. Aug 3, 2011 at 10:28 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    I thought with ome springs you had to set it at the 0
  4. Aug 3, 2011 at 10:29 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i have hit mine a couple times without spacers.
  5. Aug 3, 2011 at 10:31 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    So if those really are 885's (I agree with Mike they look like eibachs to me), you have springs rated for 2.5" of lift, then you are preloading them another 0.85", and then you are putting a 3/4" top plate spacer on them. That's a total of 4.1" of lift. I'm not surprised at the contact with that much lift.
  6. Aug 3, 2011 at 10:33 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    My 885's are black
  7. Aug 3, 2011 at 1:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Those arent 885 springs. Anyway, Remove the Top Plate spacer, and you wont have any contact.
  8. Aug 3, 2011 at 1:32 PM
    09taco4x4
    09taco4x4 Well-Known Member
    Louisiana
    09 DCLB TRD Sport 4x4
    Valant cold air intake kit Borla catback exhaust 6" Pro Comp Stage 1 Walker Evans 2.5's w/ TSB spring and add-a-leaf Light racing upper a-arms 285/70/R17 Dynapro ATM tires 17x9 XD wheels
    I thought the top plate spacer was suppose to be installed on the driver side..........:confused:
  9. Aug 3, 2011 at 4:14 PM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Our thoughts exactly. If that is an 885 that you repainted silver, you are running way too much lift up front! What's your center hub to fender measurement up front? If your over 23-23.25", you are over 3"
    Please feel free to PM or call us
  10. Aug 3, 2011 at 4:23 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    is your uca on the wrong side? looks odd to me.
    edit: nah, maybe its not
  11. Aug 3, 2011 at 6:49 PM
    DDD
    Derek
    Santa Clarita, CA
    Thanks for all the tips.
    They are 885 springs painted silver. They are old 885 springs that I bought used. They were giving me about 2 inches of lift with the 5100 shocks set at zero.
    I tried adding the top plate spacer with the shocks set at zero and the ball joint still hit the springs. So now I have just removed the spacer and set the 5100s at .85". Maybe I'll just try to sell the spacers.
    I'll have to measure my lift again. Thanks for all the help.
  12. Aug 3, 2011 at 6:57 PM
    DDD
    Derek
    Santa Clarita, CA
    The more I think about it I guess that those 1/2 inch thick top plate spacers must not work with any shocks longer than stock.
    The only thing limiting the suspension from going down (when the vehicle is on jacks) is the extended length of the shock. So when you add a top plate spacer (above the shock) it extends the shock length and allows the suspension to extend 1/2 inch further. I am sure these top plate spacers work fine with normal length shocks, but maybe because the 5100s are a little longer than stock, the suspension cannot be allowed to extend that far down.
    What's your opinion?
  13. Aug 3, 2011 at 6:59 PM
    KPT
    09 Prerunner
    The 5100s are the same length as stock at full droop.
  14. Aug 3, 2011 at 7:00 PM
    OZ-T
    Peter North
    British Columbia
    Wouldn't a 1/2" top spacer add 1" of lift ?
  15. Aug 3, 2011 at 7:03 PM
    KPT
    09 Prerunner
    It would if it is 1/2" thick.
    It's hard to tell when folks say a 1/2" spacer if they mean one that is advertised to give 1/2" lift, or one that is 1/2" thick.
  16. Aug 3, 2011 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    At the wheel, Yes.
  17. Aug 3, 2011 at 7:04 PM
    OZ-T
    Peter North
    British Columbia
    From the pic , it looks to be 1/2" or the 10 mm
  18. Aug 3, 2011 at 7:05 PM
    DDD
    Derek
    Santa Clarita, CA
    I agree. The actual spacer is 1/2 inch thick. The Toytec website says it provides 3/4 inch lift.
  19. Aug 3, 2011 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It gives 1".
  20. Aug 3, 2011 at 7:06 PM
    KPT
    09 Prerunner
    Ding
