Top Plate Spacer Causing Ball Joint to Contact Spring
Discussion in 'ToyTec Lifts' started by DDD, Aug 3, 2011.
  1. Aug 3, 2011 at 7:07 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    So the OP had 885's preloaded with billies at .85 , and an additional 1" of lift from the top spacer .
    That's a lot
  2. Aug 3, 2011 at 7:11 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yeah even if the 885s were shot and only giving 2" of lift, he's still at 3.85".
  3. Aug 3, 2011 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    He doesnt have 885's. He probably has the 620 # Eibachs....
  4. Aug 3, 2011 at 7:12 PM
    OZ-T
    Peter North
    British Columbia
    He already said they are 885's painted silver
    FARNORCAL likes this.
  5. Aug 3, 2011 at 7:12 PM
    KPT
    09 Prerunner
    He said he bought an old set of 885s and painted them silver.
  6. Aug 3, 2011 at 7:20 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    I think the reason its rubbing is cause your at full drop. How often are you going to be at full drop when driving
  7. Aug 3, 2011 at 7:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah! I didnt see that....so....preloaded, and a spacer lift on the 885's, and he wonders what the issue may be???
  8. Aug 3, 2011 at 7:24 PM
    OZ-T
    Peter North
    British Columbia
    Or that he was almost at 4" of front lift
  9. Aug 3, 2011 at 8:39 PM
    GotLift37
    down south
    07 4Runner 4WD
    Doubtful. 4" wouldn't do that with LR UCA's
  10. Aug 3, 2011 at 8:43 PM
    OZ-T
    Peter North
    British Columbia
    What's doubtful ?
  11. Aug 3, 2011 at 11:55 PM
    GotLift37
    down south
    07 4Runner 4WD
    Plus if your worried about your ball joint boot touching your spring. Take a look at your axle it seems to look in a pretty bad bind itself.
