Top plate spacer lift on 5100s?
Discussion in 'Suspension' started by gacandido2010, Nov 20, 2011.
  1. Nov 20, 2011 at 10:55 PM
    gacandido2010
    gacandido2010 [OP] Well-Known Member
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    Bilstein 5100s, Eibach Coils, All Pro Baja Leaf Pack, Fox 2.5x16", All Pro 1.5 spacers, Deckplate Mod, K&N Filter, Magna-Flow Exhaust System, Cobra Ultra Cb with 3" Firestick, 2 Hella 500 HIDs, custom mesh grill, blacked out lettering, Limo Tint, Fog Light Mod
    wondering if it would hurt my 5100s if i put toytec front top plate spacer kit on them? i have them set at 0'' with eibach coils which gives about 3 or 3 1/2''. problem is i put a 2'' aal so my rear sits slighty higher :mad: this annoys me.
    the spacer is 3/4'' lift. and when i install it would i have to compress the the coils again or would it simply slide on top of it?
    thanks tw
    http://www.toyteclifts.com/index.ph...tegory_id=121&option=com_virtuemart&Itemid=72
  2. Nov 21, 2011 at 12:19 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Yes you have to compress the coils again. I put that set on my OME lift to compensate for the bumper and winch. Another less costly option could be to trim a little off the AALs so the rear doesn't sit so high.
  3. Nov 21, 2011 at 12:58 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    A lot of people run the Billies at .85 with eibach coils.
  4. Nov 21, 2011 at 12:41 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    i always thought u werent suppose to do tht
  5. Nov 21, 2011 at 12:42 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    That works on a 2nd gen only
  6. Nov 21, 2011 at 1:10 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    any other suggesstions to get a lil more lift in the front?
  7. Nov 21, 2011 at 2:29 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    There's not much more you can really do in the front to get more lift. Even if you did, you're likely to have more problems with your CVs and/or boots.
  8. Nov 21, 2011 at 2:33 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Throw a few sand bags in the rear to settle the AAL a bit.
  9. Nov 21, 2011 at 3:47 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    haha thts a funny fix
  10. Nov 21, 2011 at 4:02 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    oh shit u mean tht actually works? haha
  11. Nov 21, 2011 at 4:22 PM
    98toyota
    98toyota Well-Known Member
    Hawaii/Bay Area, CA
    Toytec doesn't recomend using spacers on 5100s...
  12. Nov 21, 2011 at 4:24 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    thanks guys
  13. Nov 21, 2011 at 5:19 PM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Not true but welcome. Oh maybe on a first gen.
  14. Nov 21, 2011 at 5:19 PM
    Pugga
    Massachusetts
    F-150 Mod
    Yeah man, I wasn't being a smart ass. It's risky to raise the front end any higher because you could damage your CVs, so the next logical solution would be to lower the rear. You can do that by either compressing the suspension using weight, causing it to settle down a little quicker (it will still have some rake, but it'll help) or, as mentioned above, trim the AAL so it doesn't provide as much lift.
