TOP SPEED....something is wrong....
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bino9905, Jun 17, 2014.
  1. Jun 17, 2014 at 10:33 AM
    Bino9905
    Bino9905 [OP] Well-Known Member
    TX
    99 ExtCab 4X4 V-6 TRD
    OK, so a few weeks ago i bought a 99 tacoma SR5 4X4 with 96K miles to replace my 99 TRD with 196K miles.....well im hoping i didnt get scammed.....
    I had a 2 week old baby along with my 2 year old and an angry wife at home....so I told the guy to drive it an hour to my house and I would pay him an extra 100 bucks.....
    well both babies are crying when he gets to my house....i figured it made the drive no problems and its not over heating....looks good so I only test drove around the block so I could get back home quick and reduce my wifes anger...
    I paid him and that was that...
    The first time I drove it engine light turns on....its the "bank1" code....
    Then the engine starts to ping....ok maybe its carbon deposits because truck sat a long time that why it has low miles....
    Today is first time I drive it on the highway.....with my TRD I could go 70 or 80 pulling small trailer and 4 wheeler.....
    this one I was doing 69 and I floor the pedal and nothing....seems like it was struggling to do 70 mph with no load other than me....
    What could cause that...of the line feels same as TRD or better....
    Sorry about the book, just back ground info....
    Thanks
  2. Jun 17, 2014 at 10:35 AM
    Bino9905
    TX
    does the TRD have more HP with the same engine??
  3. Jun 17, 2014 at 10:36 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    No TRD is only suspension/locker and cosmetic upgrades. What engine is in the truck?
  4. Jun 17, 2014 at 12:01 PM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    Both V6's? Maybe it just needs a good tune up?
  5. Jun 17, 2014 at 12:23 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    If you had some pinging, your ECU will pull a ton of spark timing. This and proabably a much needed tune up could be why your truck is struggling.
    Pull the plugs to see whats going on in each cylinder (diag one cylinder at time): http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp
    More than likely you are pinging in one or more cylinder. This is either from carbon build up or from insuficient fuel delivery (or both).
    SEAFOAM your engine, change fuel filter, check fuel injectors and fuel regulator. Make sure the fuel regulator has a secure vaccum fitting connected to your intake.
    Also consider cleaning your MAF, changing spark plugs as needed, and changing out your AFR / O2 sensors.
  6. Jun 17, 2014 at 12:29 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Plugs, wires, air filter, fuel filter, etc should help.
  7. Jun 17, 2014 at 12:32 PM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    this,
    did you have a V6 and buy a 4bang?
  8. Jun 17, 2014 at 1:55 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    also gears could be different, maybe old truck had lower gears than the new one which put her higher in the powerband on the highway than the new one. What about tire size vs. Previous truck? Like mentioned a good tuneup couldn't hurt and would be a good place to start
  9. Jun 17, 2014 at 2:02 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    TRD (with an elocker) had 4.10 gears. The new one might have 3.9x gears.
    Also, could be plugged cat or fuel filter?
    Or over-size tires without a re-gear?
  10. Jun 17, 2014 at 2:31 PM
    Bino9905
    TX
    Thanks for response....I had mechanic change plugs, wires & air filter, I will change the fuel filter.....hoping its lack of fuel...(maybe thats why "bank1" lean code is showing)
    also my old one did have the E-locker so difference in gears could make sense....
    Even with the gears this thing should do 90 MPH with no load right?
    They are both 3.4s......i will see on the way home today i will get on highway and see if it will hit 75......
    If its not the fuel filter......thats going to suck
    Can you check for plugged cat or is changing it the only option?
    I would like to test it first, a muffler shop should be able to test it right?
    Im also going to do the MAF cleaner and seafoam into the intake....i have never done it before but was told it could help with pinging
    Right now all i have done is add Lucas fuel additive and the tune up...
  11. Jun 17, 2014 at 2:32 PM
    Bino9905
    TX
    tires and suspension is all stock on both trucks
  12. Jun 17, 2014 at 2:34 PM
    Bino9905
    TX
    Everything sounded fine, it just seemed moving along like i was not pressing on the gas.....revs were not going up....it was just weird....the wire pulling the throttle at engine might not be adjusted.....just because I have it to the floor doesnt mean its pulled all the way under the hood....is that possible or only with carburetors
  13. Jun 17, 2014 at 3:09 PM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    I have the 3.9 gears and the 3.4 and I cruise at 80 at times but never have tried to see how fast it would go but its not struggling cruise at 80. Ive never done seafoam but when I had my injectors cleaned my truck had quite a bit more pep to it
  14. Jun 17, 2014 at 7:34 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    That's very possible, yes. Did the mech check your plugs?
  15. Jun 24, 2014 at 8:46 AM
    Bino9905
    TX
    Ok, well I changed the fuel filter and nothing still bogging down at 50 MPH and would not go above 70 no matter how long i held the pedal down....no hesitation, just no response....
    I then took out the MAF and cleaned it pretty good, put it back in and nothing....still the same....
    I had never used Seafoam so I was hesitant to do so.....after a couple of youtube videos I decided i would try it.....
    one can of seam foam and 15 minutes later she was fixed!!!!!
    I could not believe it.....i put some in to the intake vacuum line, then let it sit 15 minutes....i turned it on and reved/smoked the engine for about 3 minutes
    I then got it and got on the highway.....i could not believe it.....im doing 85 and still room under the pedal....quick response and the ping/knocking noise at low speeds is also gone.....
    I have never been so happy after using a product like that.....pretty cool....Seafoam rules......
    What part do you all think was gummed up so bad.....intake valves??
    Thanks
  16. Jun 24, 2014 at 10:08 AM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    Glad to hear things were resolved. Seafoam is in my near future as well. As far as how fast these trucks can go stock, I've been in double cab (can't remember if it was a 2.7 or 3.4 and no idea what the gearing was) that could handle 120mph. I was a passenger and terrified :eek:, as we were on a freeway outside Sacramento at night with a bunch of others on the road.
  17. Jun 24, 2014 at 11:53 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Sounds like some carbon build up in your combustion chamber was causing you to ping which cause your ECM to pull your timing.
    Make sure you are running good gas to keep deposites from forming.
  18. Jun 24, 2014 at 3:10 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    Any old gas that you may have had in the truck...get it burned and get new stuff in there. The new ethanol gas destabilizes far faster than regular gas with no ethanol in it. I wouldn't hesitate to run a bottle on fuel injector cleaner on your next full tank of fuel either.
  19. Jun 24, 2014 at 7:18 PM
    Huntn57
    Huntn57 Well-Known Member
    Justin
    VA
    1995 Toyota Tacoma
    i com 2300 ham radio. for hunting (170 k miles) list of replacements since 166k miles: 4wd solenoid tailpipe muffer catalitytic conver exhaust manifold
    should do better than 70 my cousins truck will do 83 and its got 226 with orig plugs. no tune up
  20. Jun 24, 2014 at 7:19 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    That was you?!
