Top TSB's that you recommend before warranty expires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tony92629, Feb 15, 2011.
  1. Feb 15, 2011 at 12:42 PM
    tony92629
    tony92629 [OP] Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    Other than the leaf spring upgrade (Already done)...what other TSB's do you recommend being completed before the warranty expires?
  2. Feb 15, 2011 at 12:48 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Do you have a hang in the shifting between 1st and 2nd at rolling stops ?
  3. Feb 15, 2011 at 1:11 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    2012 TRD Sport 4x4 DCSB
    Stow-away roof rack, Entune navigation, Aero Turbine 2525 muffler, Tan Softopper.
    ^ To that TSB, I was told I had to get my pedal chopped or else they wouldn't do the transmission. So I said no despite really wanting it.:(
  4. Feb 15, 2011 at 1:13 PM
    OZ-T
    Peter North
    British Columbia
    That's dumb , the pedal trim is un-noticeable , but the shifting is greatly improved . Your choice .
  5. Feb 15, 2011 at 1:13 PM
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Pedal chop is nothing... Get the tsb since the reflash fixing the transmission hang is much better.
    Also the TSB for the rattle in the steering column was quite nice.
  6. Feb 15, 2011 at 2:00 PM
    tony92629
    Tony
    Dana Point
    Yes - I told my service guy about this one. It really bugs me. Knew blower motor on back order....But, I am in the system! Thanks
  7. Feb 15, 2011 at 2:02 PM
    tony92629
    Tony
    Dana Point
    Great! Thanks for the help - keep 'em coming if you have any more ideas!
  8. Feb 15, 2011 at 2:03 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Auto transmission shifting TSB. I was sooo pissed with the transmission before the reflash. All is good now! :D
  9. Feb 15, 2011 at 2:06 PM
    OZ-T
    Peter North
    British Columbia
    Agree 100%
  10. Feb 15, 2011 at 8:06 PM
    Node
    Node New Member
    TRD 4x4 6sp OffRo'ad
    hahaha, automatics...
  11. Feb 15, 2011 at 8:08 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    Automatically awesome.
  12. Feb 15, 2011 at 8:40 PM
    OZ-T
    Peter North
    British Columbia
    Have fun with your TOB :)
  13. Feb 15, 2011 at 11:05 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The Pedal chop is a RECALL.
    Not the same as a TSB.
  14. Feb 15, 2011 at 11:38 PM
    Derpy Derek
    Derpy Derek Derp
    Derek
    Lindale, TX
    I know that, apparently the dealership doesn't care..
  15. Feb 15, 2011 at 11:40 PM
    OZ-T
    Peter North
    British Columbia
    More than likely , the dealer's position is that if they do any work on your truck , including the TSB you want done , that they would then have to do the recall work as well , which involves the pedal trim and the brake override software update .
    Seriously , the pedal trim in a non issue .
    Zero .
  16. Mar 4, 2011 at 8:38 PM
    Seandaman
    Seandaman Active Member
    Cincy, OH
    08 4wd dc, Off Road pkg
    Banks exhaust, volant cai with ram air, BF All Terrains
    Had the transmission tsb done yesterday, it's a night and day difference.
  17. Mar 4, 2011 at 8:40 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    how many miles and what not before you guuys actually went and got these TSBs done??
  18. Mar 5, 2011 at 4:52 AM
    Seandaman
    Cincy, OH
    57000, needs a new valve cover gasket also.
