Topper 3rd brake light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mitchelodeon, Jul 15, 2023.
  1. Jul 15, 2023 at 3:05 PM
    Mitchelodeon
    Mitchelodeon [OP] Member
    Mitch
    2022 Lunar Rock Tacoma TRD OR
    Need help! Just installed a 3rd brake light on my soft topper.
    Don't know what's wrong.
    Everything works normal when headlight DRLs are on. When I turn the headlights on, I'm having issues getting the 3rd to react to the brake pedal.
    Brake lights didn't come with any how to. It's a Morimoto motorcyle brake light. Figured i could make it work as a 3rd brake, but i also don't know electrical. Lol
    it had 3 wires attached to the light. Tapped all 3 into the 3 on the brake harness.
    Red went to #1 (power)
    Yellow went to #2 (?)
    Black went to #3 (ground)
    Every video I watch on 3rd lights, they only have 2 wires to tap into. When I did just 2 (red, black), all 3 lights were on, but didn't react when the brake was pressed. This is why I tapped into the #2 wire with the yellow wire from the brake. 3 wires on both harnesses made sense that the issue would correct itself. Now the standard brake lights react, but the 3rd light is just on with zero reaction.
    Any help appreciated.
  2. Jul 15, 2023 at 3:26 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    what do the instructions say the wires do?
  3. Jul 15, 2023 at 3:36 PM
    Mitchelodeon
    Mitch
    Nothing came with the brakes for instructions. I've just been referencing people wiring their topper lights via YouTube. But everybody only deals with 2 wires (#1, #3) wires.
    If I'm guessing correctly, the 3rd wire needs to tap into a running light wire? But idk where that is.
  4. Jul 15, 2023 at 3:41 PM
    Mitchelodeon
    Mitch
    I just found installation instructions. It says red wire is dim light and yellow is bright light.
    Any idea where I would tap these into?
  5. Jul 15, 2023 at 3:49 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Just get the harness from @Puppypunter . He’s the guy. It’s plug and play. You really don’t want to tap on those wires and cause a short in the future . Think rain. Got one when I placed 3rd bl on my softopper a while back. It’s perfect.
  6. Jul 15, 2023 at 3:53 PM
    notbryon
    notbryon Well-Known Member
    Bryon
    Steelton, PA 17113
    2017 TRD Sport AC
    ^^^ this
  7. Jul 15, 2023 at 3:53 PM
    Tacospike
    Two Trucks
  8. Jul 16, 2023 at 8:03 AM
    soundman98
    NW Indiana
    that helps
    ignore the red, tape it off. connect the yellow to only the brake signal. black goes to ground of course. CHMSL's should not have a dim function.
  9. Jul 16, 2023 at 8:46 AM
    christsay
    christsay Well-Known Member
    chris
    Austin, TX / Santa Fe, NM
    2021 Army Green DCLB TRD 4x4
    JB Grand Raid Evo XXL mounted on an Alu-Cab. 5.29 gears.
    But it'd be a great way to confuse people behind you. "Is he braking, no, wait, yes, now he is, is he? I can't tell"
  10. Jul 16, 2023 at 5:54 PM
    soundman98
    NW Indiana
    which is technically a DOT lighting standard violation, which, if the person running into the back of the truck is knowledgeable enough, would make the tacoma driver liable for all damages...
    lots of risk for zero reward, imo.
