Topper Brake Light Tap with Meso Total Tail Stage 1
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, Apr 19, 2023.
  1. Apr 21, 2023 at 7:04 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I swear I've seen them cheaper:
    https://www.curtmfg.com/part/56070
    But one of those, plug it in, route it where you want, then either mount it and get a 7 pin pigtail or cut out all but the brake controller lead and the ground lead, then heat shrink (or electrical tape) the unused wires and bury them in the loom.
    Brake T from me or another curt harness gives you the brake input.
    Brake Controller Harness -- just join the blue and black together with a butt connector and ignore the other wires or de-pin and remove them.
    Now you have fused power, ground and brake (aka stop) feeding the shell. Any 3 position quick disconnect and some heat shrink butt connectors.
    Tools required: 1 pair of wire strippers, 1 heat gun or hair dryer, some electrical tape or friction tape, heat shrink butt connectors.
    Time required: 1-2 hours?
    Difficulty level: 2 out of 10? Really not any harder than any other job.
    The PIA part about self install is you have to rent a trailer to pick up the shell, most dealers won't let you bolt it on on site without charging for installation and won't let you drive off without a functioning 3rd brake light. That's where they f you over. I rented a trailer to pick mine up b/c that pissed me off so much but it was significant headache.
    Another note on the above items, you can do 90% of the prep work in advance, on the bench. The last bit is marrying up 3 wires with some sort of quick disconnect. Lots of options there and doesn't really need to be waterproof but an AMP w waterproof cap or dutsch flange or weatherpack would be on my list.
    F it man, I'd even do the prep work for you if that helps.
    tonered and FL_TRD Sport[OP] like this.
  2. Apr 21, 2023 at 7:14 AM
    FL_TRD Sport
    FL_TRD Sport [OP] Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    @daveeasa If I get your harness (I assume the regular is what I need), does it plug in at the Meso Total Tail stage 1 to OEM harness end or the Meso to tail light end? Or does it matter? :)
  3. Apr 21, 2023 at 7:15 AM
    daveeasa
    David
    PNW
    Upstream, but it also doesn't matter if you did it wrong because total tails is re-routing turn to the switchback, the brake bulb gets the same signals as before.
  4. Apr 21, 2023 at 7:16 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Ok to between the Meso and OEM harness. Got it thanks :)
  5. Apr 21, 2023 at 7:22 AM
    caribe makaira
    Caribbean, Puerto Rico
  6. Apr 21, 2023 at 10:34 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I dont have any pictures, but I tapped into the meso harness and installed a flush mount SEA plug in the bed. That way when I dont have the topper there are not wires just hanging out. Makes it much cleaner and easy to work with.
    FL_TRD Sport[OP] likes this.
