Topper cap with bed stiffeners or just divider?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hammerma, Sep 14, 2020.
  1. Sep 14, 2020 at 9:13 AM
    Hammerma
    Hammerma [OP] Well-Known Member
    2019 trd sport
    I have an ARE MX ordered for my 2019 DCSB. I currently have a bed divider installed which
    seems pretty heavy duty. The bed divider seems like it would help keep the box sides vertical.
    Should I get bed stiffeners also? Thanks
  2. Sep 14, 2020 at 9:19 AM
    DefinitelyThor
    DefinitelyThor Well-Known Member
    Utah
    2018 Black Trd Pro
    it depends on if its bolted to the sides of the bed, i had to drill holes in my bed to get the stiffeners in and i have a friend who has a drawer system we made out of wood and it made the bed bow out even more so i went in and bent the bed back in and bolted it to the drawer system to help it and it hasn't bent out again since
  3. Sep 14, 2020 at 9:20 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I'm not sure how much the divider would help, but it would add some rail to rail rigidity. The bed stiffeners are pretty heavy duty and structurally mount where the OEM steel structure are. I'm not convinced that stiffeners are mandatory, but I added a set of Cali raised for my LB after getting my cap installed and they did align the tailgate gaps more evenly (pulled the bed in slightly). Another thing to consider is getting some sumo springs or similar. My top might be a little heavier if you are in a short bed, but the cap weight brought my back in down a bit. I added Sumo Springs 612-40s and they raised it back to closer to factory height and reduced body roll in turns. I love having the cap though. Sat in there for an hour Saturday with my wife and son watching my daughters soccer game in the rain.
    AMSK.505 likes this.
  4. Sep 14, 2020 at 9:21 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Honestly, I think you'll be fine with nothing, but the divider and stiffeners will help.
    The divider will hold the sides together, but in theory both sides could fold in the same direction. Again, in theory, the stiffeners will keep the sides 90°.
    I'd recommend stiffeners as they will provide more tie down locations. They're worth it for that alone.
  5. Sep 14, 2020 at 9:27 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    For me I ended up putting stiffeners after the fact. I regularly put at least 100 lbs of stuff (boats and wet gear) on top of my racks and go over some ruff roads. I noticed the shell and bed were moving around more than I felt comfortable with while going over big roots and rock so installed without taking shell off.
    If you aren't putting much weight on your racks or staying on decent roads id say you're fine without
  6. Sep 14, 2020 at 9:33 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    yea, mine was getting bent out after maybe a month of having a topper because i tend to launch of really steep and rocky hills on a daily basis with a bed full of camping and shooting gear for my summer job
  7. Sep 14, 2020 at 9:37 AM
    DiscoYaker
    SE USA and Alaska
    Also, if you do go this route i wouldn't go with the cheap 50$ ones on ebay or Amazon
    You will have to drill holes and don't tighten down the smaller factory bolts (that you reuse) to tight because they will snap pretty easy. Its not in the picture but I did that to the very top one on the other side
    I wouldn't install just for looks but thats me
    Some of them come with a bottle opener...
  8. Sep 14, 2020 at 10:20 AM
    Hammerma
    2019 trd sport
    Ok thanks for all the input. I just put in an order for Rago Fabrication channel stiffeners $125.
    BTW ARE toppers are now 10-11 weeks out on orders. Wish Snugtop was available in MN.
  9. Sep 14, 2020 at 10:30 AM
    Tacoma091919
    Tim
    2019 OR DCLB
    I am VERY happy with my ARE CX. It was about the same when I ordered mine for lead time, they are built to order. Mine is perfect in terms of QC. ARE CX Classic (cab height) long-bed, MGM (perfect match), carpet, vented windoors, fold down sliding window. (I installed my own net system in the top of the interior). Snug tops are great too, but I think all the manufacturers are on par, and I am really happy with my ARE. Installation matters a lot, make sure they take your rails off and silicon and add the filler kit on the front of the bed rack. Mine stays bone dry.
    betor likes this.
  10. Sep 14, 2020 at 12:21 PM
    Hammerma
    2019 trd sport
    Good to hear. I just don't want to wait till it's winter to get it. I believe Snugtop also
    offers a sliding windoor for DCSB which nobody else has.
  11. Sep 14, 2020 at 12:23 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    really? thats the only reason i have a snug top?
  12. Sep 14, 2020 at 1:14 PM
    Hammerma
    2019 trd sport
    snugtops closest dealer is 1000 miles away
  13. Sep 14, 2020 at 1:17 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I went with TC bed stiffeners, shown above, no experience with the divider though.
  14. Sep 14, 2020 at 3:02 PM
    Tacoma091919
    Tim
    2019 OR DCLB
    Yeah I’ve heard nobody else does vented windoors for short bed. You can get a windoor or a vent but not both. Not sure why.
  15. Sep 14, 2020 at 3:10 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    I just ordered a LEER 100R with vented windoors for a short box... Pics in a month! ;)
  16. Sep 14, 2020 at 3:48 PM
    Tacoma091919
    Tim
    2019 OR DCLB
    Wow nice, I’ve seen numerous posts that say Leer wouldn’t do it. It makes sense they should since Leer, Century, and Snug Top are all owned by the same company. I think the reason ARE doesn’t is the vented windoor design is different.
  17. Sep 14, 2020 at 4:01 PM
    Hammerma
    2019 trd sport
    I guess we will see in a month. I was looking at the ARE MX or Leer 180
    For a short bed, it’s unavailable
  18. Sep 14, 2020 at 7:15 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Ive got them on my ARE v series 5ft bed
    AMSK.505 and TroutBum like this.
  19. Sep 14, 2020 at 8:29 PM
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    The one in Chicago? That's where I went (Tri County Trucks, or something like that... good installers)
  20. Sep 14, 2020 at 10:02 PM
    ActionHank
    ActionHank Well-Known Member
    Action
    I drive a honda
    I drove from Michigan to Chicago to get mine. I have a snugtop rebel with Sportsman pack because I wanted something reinforced. I liked the leer but they didn’t have anything strong, and the ARE’s have that internal steel structure that would have cut in storage space.
    FYI totally worth it.
