Topper clamps- is there something better?
Discussion in 'Tonneau Covers, Caps and Shells' started by solgardener, Sep 7, 2018.
  1. Sep 7, 2018 at 12:25 PM
    solgardener
    solgardener [OP] Well-Known Member
    William
    '14 Tacoma DCLB SR5
    s.e.charles and JimboAnz like this.
  2. Sep 7, 2018 at 12:28 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    can you add some rubber strips on top of the bedrail to create some grip? maybe :notsure:
  3. Sep 7, 2018 at 12:32 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I have a soft top and use these type of clamps. Shouldn't your topper have a rubber seal between the bed and bottom of topper? Are the clamps tight enough?
    You can always add more clamps to make sure it stays put.
  4. Sep 7, 2018 at 3:54 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Home depot sells a waterproof weatherstripping sticky on one side. It is 1”” thick but squishes down to create a tight seal if there is impurities in the fibreglass.
  5. Sep 8, 2018 at 2:41 AM
    solgardener
    William
    '14 Tacoma DCLB SR5
    The weatherstrip that was under it from the install worked its way out. It's the 1/4" x 2" stuff. I bought some better rubber seal to replace it. It wasn't cheap, so I want to be sure the shell doesn't shift afterwards.
  6. Sep 9, 2018 at 5:53 PM
    Phoenix2000
    Phoenix2000 Well-Known Member
    Bryon
    Phoenix, AZ
    2006 Toyota Tacoma
    CanBack Canvas Camper Shell, Mickey Thompson Wheels, Daystar 2.5" Lift, IronCross Bumpers and Step Bars, HushMat Sound Dampening
    Those are the industry standard clamp design.
    If it is sliding, then you do not have enough friction. Put a seal under the rails, and/or rough up the top surface under the clamp. Also check the tension bolts every now and then to make sure they have not loosened.
    If you want a mechanical stop, then drill and countersink for 8-32 x 3/8" flat head screws, with the head under the rail and a lock nut on top and then butt the clamp against the nut.
  7. Sep 9, 2018 at 10:50 PM
    Phoenix2000
    Bryon
    Phoenix, AZ
    2006 Toyota Tacoma
    s.e.charles likes this.
