Topper install question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bajarick, Jan 15, 2023.
  1. Jan 15, 2023 at 9:08 AM
    bajarick
    bajarick [OP] Member
    rick
    2011 tacoma
    stock
    Hi. Just got a 2011 access cab. I need to put a shell on it. Haven't found the shell yet but.... I just saw how to remove the bedliner rail caps. And saw what it looks like underneath. When I put on a shell I usually bolt through to keep it secure. I live where things come loose! How are most newer toppers connected to the bed? Would love to leave that rail liner on but don't see how it could be fastened down.
    Thanks
  2. Jan 15, 2023 at 9:31 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Most often with C-clamps mounted to the bed rails. You'll also want to pick up a correctly sized seal for the front wall of the bed.
    This post gives part numbers for all of the seals necessary to get a good fit on 2nd gens.
  3. Jan 15, 2023 at 9:56 AM
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    I recently bought a used Leer bed cap, shell, topper, whatever you want to call them.
    The Leer that I got has pieces that slide into the rail and bolts that attach to them.
  4. Jan 15, 2023 at 9:57 AM
    Madd Matt
    Welcome to the forum.
  5. Jan 15, 2023 at 9:59 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    does your 11 have the bed rails that take T-Nuts? that is how mine attaches, the t-nut slides into the track, and then bolt though the holes/tabs in the topper.
  6. Jan 15, 2023 at 10:06 AM
    bajarick
    rick
    2011 tacoma
    stock
    Thanks everyone! Things have gotten fancy since my last shell! Searched the site more and found the clamps that use the inside rail! Might get 8 instead of four.
    rick
  7. Jan 15, 2023 at 10:16 AM
    BigCountry762x39
    TL
    PNW, Oregon!
    well, depending on your cap you may only have the provision for 4, mine the tabs are fiberglassed into my topper. my topper hasn't moved, though if you're planning to pull the plastic top caps i might recommend, throwing some butyl rubber down under all that and along the front since that seems to be where most leaks from up front.
