Topper Mounting Problem Caused by Narrow Bedrails
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Nov 5, 2011.
  1. Nov 5, 2011 at 2:43 PM
    skeezix
    skeezix [OP] The Voice of Experience (mostly negative)
    Colorado
    1998 Limited
    The bedrails on my 1998 Tacoma are only about an inch wide, and I want to mount a topper over the bed. I don't like J-clamps so I'm going to hard-fasten the topper using nuts and screws. To widen the top surface of the bedrail I fashioned some runners using 1-inch aluminum L-stock and was going to screw the runners to the inner edge of the bedrails. Then I would screw the topper to the horizontal surface of the runner.
    Unfortunately, the vertical edge of the bedrail is not perpendicular to the rail's top surface. When I attach the right-angle runner to the slightly-out-of-plumb bedrail the top surface of the runner will tilt up towards the center of the bed. :( Please see the attached crude drawing.
    What would be a good way to overcome this problem? Would using rubber mounting gaskets (available by the foot) for the seal be a better solution than using the usual foam tape? Any and all comments are appreciated.
  2. Nov 5, 2011 at 3:44 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The previous owner of my truck used c-clamps and cut notches in the topper (v shaped).
  3. Nov 5, 2011 at 3:47 PM
    cstephan
    cstephan Well-Known Member
    Carl
    Winchester Va
    13 Taco TRD Gov. Controled Special
    Hold my BEER and WATCH THIS
    Shim it.
  4. Nov 5, 2011 at 4:05 PM
    skeezix
    Colorado
    1998 Limited
    Aw that's too simple ;)
    Seriously, I thought about that but due to the way the base of the topper is molded (it has an inside lip that I forgot to include in my drawing), I thought that placing enough shims to level the runners would bring the edge of the runners too far away from the bedrail to fit the base of the topper.
    I'll go out to the garage and remeasure everything - maybe the topper will indeed mount properly. If not, maybe I can install the runner and use vicegrips to slowly and carefully bend the vertical part of the rail so it is 90 degrees from the top surface.
    Thanks for the idea!
