Topper Wiring - Advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by dinosaurjr, Jun 8, 2021.
  1. Jun 8, 2021 at 9:52 AM
    dinosaurjr
    dinosaurjr [OP] Member
    2004 Tacoma Xtracab SR5 V6
    Howdy, I know there’s plenty of threads and videos on wiring a camper top but I’m having a little trouble connecting the dots (first truck, I’m learning.) Basically I want to wire a harness from my 3rd brake and dome light and I need some confirmation / advice on my setup.
    I’m planning to wire brake and dome ground blacks together and to ground on the 4 pin, white to white on the 4 pin trailer harness. Red brake to green harness, red dome to yellow harness. So far so good? This is all from videos I have watched. If I'm wrong, holler.
    My next steps are a little murky. I have a trailer harness on the underside of my bed. It looks old and corroded, I bought this truck used so no idea if it worked. I would imagine if I poke some leads from my multimeter in there I should get some read but I’m drawing zero. What would be your next step here? Follow back, check connections? Replace 4 pin?
    Finally, I gotta get from the 4 pin under the bed up into the bed. Was planning on buying 4 pin extension, cutting off one end, fishing wires through tail housing and into bed and re-wiring so I have an easy access quick connect for the 4 pin coming from 3rd brake/dome. Make sense?
    Better ways to do any of this, overall advice appreciated. I'm new go easy. Thanks y’all.
    Dome and 3rd
    Crusty 4 Pin from under bed
    Need to go from 4pin dangling up through
  2. Jun 8, 2021 at 9:55 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Most topper wiring for brake and dome use the connections in the taillights. There is one guy making plug and play for 2nd and 3rd gens. Might have a 1st gen or be able to wire it up. Made that job super easy. You can also tap into the lights directly. That is how my toper was setup. For the Dome likely similar but cant recall. I was running a battery-operated version in my topper.
  3. Jun 8, 2021 at 11:47 AM
    dinosaurjr
    Yeah I was originally going to tap into the brake light harness and go that route but then I noticed I already had a 4pin trailer harness underneath my bed. I can’t seem to get any reading on my multimeter through it though so I’m wondering if I just leave that for dead and tap the lights like many others have done or if I should get another 4pin to replace the corroded one I have now. Also I found that thread from the dude making the plug and plays and asked him about 1st gen version, maybe that will work out. Thanks.
    pkeawe likes this.
  4. Jun 8, 2021 at 11:53 AM
    nudavinci64
    Robert
    nice as long as he has the plugs he should. may get lucky and it's similar to existing. But if you in a hurry id go with the tail lights. that's the go-to for topper installs at a dealer. T tap, or similar and good to go.
  5. Jun 8, 2021 at 1:08 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    It was probably overkill, but I bought a plug and play trailer harness and switched around the pinouts so that it serves as a canopy harness. I didn’t want to cut into my oem wiring. I know that most people do with no issues but I figured that it would be nice to keep it intact as much as possible. It also makes the canopy plug n play if I ever choose to sell it. If I find the pictures i took I’ll post them here for you.
    dinosaurjr[OP] likes this.
  6. Jun 8, 2021 at 7:10 PM
    nudavinci64
    Robert
    Nice. The plugs the one guys makes for the lights is similar. For the ones folks tap they usually add a plug and play connector so you can remove. I’m in the priciest of trying to make everything for plug and play so it can be removed.
  7. Jun 8, 2021 at 8:00 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    also try to tap into the wiring before the tail light housing connector, that way if you ever need to remove the tail light you won't have to re-wire
    for my ARE LED 3rd I just used wire taps and ran a 22 awg connector I bought online, makes disconnecting easy when I remove the cap
    if you want to use the trailer harness then buy a connector kit (male/female plugs) and use the wire to cut your existing corroded connector and use the new one.
    then if you have enough wire (or get a couple feet of it) and solder/shrink tube when you wire the new connector in to run up to the cap.
    unfortunately if you want an always "hot" light you will need to run a length from the battery or separate fuse box to the dome. otherwise you will need to have your running lights on to use it :/
  8. Jun 9, 2021 at 7:39 PM
    dinosaurjr
    Thanks @frizzman — that was a helpful reply. For the dome, is there a way to tap into the current map lights wiring or is there a spare fuse that could be utilized for that? I’d rather tie into a fuse than just go direct to battery I think?
  9. Jun 9, 2021 at 10:21 PM
    Madjik_Man
    Colorado Front Range
    I used a trailer harness plug for easy quick disconnect and reconnect if you remove the topper. I bought a four pin one, even though only three wires were needed. I just cut one of the wires off the plug.
    As Frizz said, tap into the wire bundle before the tail light.
    Here's a picture of what I did:
    1. is the where I tapped into the factory wire that powers the brake light. It’s in that wire loom bundle.
    2. is the ground wire that I connected to the bumper bracket.
    3. the wire just left of the number is the power lead I ran from my (+) battery terminal. This is so the dome light can be constant hot.
    4. is all three new wires (truck side) that I ran. I bundled them together, taped them together then ran them up into the bed and connected them to the trailer plug.
    5. is where I ran the three new wires up into the bed.
    I labeled each red wire (only color I had) so that I could keep track of what was what when I connected it to the trailer plug.
    chrslefty and dinosaurjr[OP] like this.
  10. Jun 9, 2021 at 10:40 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    can't see the first pic you are referencing
    but yeah, I think the 4-wire is like 14 awg and truck wiring is about 18ish? so you will have a little difference.
    @dinosaurjr just run a length directly from the + terminal ring with an add-a-fuse and call it a day :)
    I want to run a separate fuse block in the rear later on I just have to make myself do it. As for an empty fuse, I don't think there is one that is wired, you would have to open the fuse box and add the wires in and then run them back
  11. Jun 9, 2021 at 10:41 PM
    Madjik_Man
    Son of a... you don't see the picture with my drawn in reference numbers?
  12. Jun 9, 2021 at 10:44 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    nope, just an IMG tag :/
  13. Jun 9, 2021 at 10:50 PM
    Madjik_Man
    I suck at interneting.
    How about now? (above post)
  14. Jun 10, 2021 at 9:23 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
  15. Jun 10, 2021 at 9:29 AM
    taco-99
    taco-99 Active Member
    2008 Silver Taco, 2.7L /5 speed
    Twin stick shifter from Front Range Offroad on FJ Cruiser manual transfer case., Detroit/Truetrac LSD rear, ARB Roo Bumper, Warn winch, Matching A.R.E. fiberglass camper shell with roof rack.
    I see both pix, in post #9 above.
  16. Jun 10, 2021 at 10:25 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yep, I can see them now
  17. Jun 10, 2021 at 11:06 AM
    yotadude520
    yotadude520 Well-Known Member
    Will
    The Dirty T
    1986 Toyota Land Cruiser
    OME Lift - FJ62 Axles - 33x10.50 BFGs
    You can buy a harness that plugs directly into the tail light OEM from Toyota. I picked mine up yesterday I can get a picture of it for ya. It's plug and play.
    Here's the part # PTS053505DWH and it's $14.
    chrslefty and frizzman like this.
  18. Jun 10, 2021 at 11:30 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    ooo, interested in the pic. this sounds awesome
    yotadude520[QUOTED] likes this.
  19. Jun 10, 2021 at 12:53 PM
    Madjik_Man
    Where dafuq was this when I was wiring my toppers?
  20. Jun 10, 2021 at 1:32 PM
    yotadude520
    Will
    The Dirty T
    So I feel like I've been deceived a little bit. The sales guy told me it plugs into the tail light harness. It looks like it's just a universal harness with a fuse block, those cheap wire splice connectors. But I mean, it IS OEM Toyota....
