TopperEZLift
Discussion in 'Tonneau Covers, Caps and Shells' started by gnardoggie, Jul 18, 2018.
  1. Jul 25, 2018 at 11:05 AM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    @gnardoggie can you post a better pic of how the actuators are mounted to shell.
  2. Jul 25, 2018 at 11:08 AM
    gnardoggie
    gnardoggie [OP] Well-Known Member
    Yea - I can try to get some tonight.
    They essentially have a mounting plate that goes underneath through a hole in the flange of the shell and then their bracket sandwiches onto it.
  3. Jul 25, 2018 at 11:10 AM
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    :thumbsup:
  4. Jul 25, 2018 at 11:11 AM
    Taco TRQ
    Taco TRQ Well-Known Member
    TuRDTaco
    If you're feeling motivated and confident, I'd be curious for you to raise the shell and give it a shove from the top and see how solid the setup is like that. Can you easily shake and sway the truck? That would surely make me more confident.
    Another question, does the camper shell bolt to the bed with any other attachments other than the actuators? I'd also love to hear how it holds up to washboard roads and stuff. And if you feel like jumping it.... (kidding)
    Have a good one-
    BlownOutTaco likes this.
  5. Jul 25, 2018 at 11:13 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    What did it cost you?
  6. Jul 25, 2018 at 11:27 AM
    gnardoggie
    I've done that. There is some play in the system, but nothing that seemed too concerning from my perspective. I'll have to get a full test in this winter.
    The shell bolts to their brackets, which bolt to the actuators, which bolt to the bedrails and the bed. I've taken in on FS roads and haven't seen any shifting or movement. It seems to be just as secure as the bedrail brackets that I used previously. The actuators get installed slightly elevated from the lowest point which forces the cap to clamp solidly onto the rails when lowered completely.
    InstantCrackers likes this.
  7. Jul 25, 2018 at 11:29 AM
    gnardoggie
    it's on sale right now for $2k it seems
  8. Jul 25, 2018 at 11:31 AM
    Wolftaco0503
    Adam
    Chicago
    THANK YOU
  9. Jul 25, 2018 at 1:08 PM
    BlownOutTaco
    BlownOutTaco Well-Known Member
    Shane
    2018 Black DCLB OR
    Might be relatively straightforward to X brace it with nylon cam straps at sides and cab end. In theory your diagonal strap lengths will max out in the elevated position, so you could just tighten once at full lift and allow them to droop when in lowered position.
    Obviously bracing the end of the bed is tricky since you’re getting in/out through there.
  10. Jul 25, 2018 at 1:15 PM
    Taco TRQ
    TuRDTaco
    Yup, crossed my mind!
  11. Jul 29, 2018 at 6:46 PM
    gnardoggie
    Jamart5 and I married my tacoma like this.
  12. Jul 29, 2018 at 9:02 PM
    Kelly6773
    Kelly6773 Well-Known Member
    Bob
    SC
    18 TRD sport DCLB
  13. Jul 29, 2018 at 9:16 PM
    gnardoggie
  14. Jul 29, 2018 at 9:18 PM
    Kelly6773
    Bob
    SC
    18 TRD sport DCLB
    Self tapping screws for the top cap side? I’ll assume it bolts to the rail?
  15. Jul 29, 2018 at 9:20 PM
    #35
    gnardoggie
    No - for the bottom of the actuator as per your question.
    There is a bracket that bolts to the rail, which I show in my photo above.
  16. Aug 4, 2018 at 8:55 AM
    #36
    BlownOutTaco
    Shane
    2018 Black DCLB OR
    Install today.
    Wiring question: Did you end up removing tail lights to run the jump wire?
    Edit: Found the taco specific install info on their site. Looks like wiring can run via weep holes & storage bins.
  17. Aug 4, 2018 at 5:14 PM
    #37
    gnardoggie
    That's correct. I ended up just drilling small holes in the bed to run the wires.
  18. Aug 6, 2018 at 1:29 AM
    #38
    BlownOutTaco
    Shane
    2018 Black DCLB OR
  19. Aug 6, 2018 at 5:50 AM
    #39
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    NICE
  20. Aug 6, 2018 at 1:20 PM
    #40
    gnardoggie
