Toppers and gas mileage
Discussion in '4 Cylinder' started by My4x4Tacoma, May 14, 2012.
  1. May 14, 2012 at 5:05 PM
    My4x4Tacoma
    My4x4Tacoma [OP] Member
    2012 Reg Cab, 4x4, I4
    Now have a little over 1400 miles on my 2012, regular cab, 4x4, manual transmission. I kept speeds pretty low, below 60 most of the time and drove backroads instead of interstate for approximately first 500 miles. Now driving between 60 and 80 on interstate for 90 mile round trip to work. A few miles is city.
    First few fillups were 24+ mpg. Tonite filled up on way home and mileage is up to 25.43.
    I am happy with 25 mpg. I would like to put a topper, probably leer on the truck.
    What kind of change in mpg should I expect with a topper ?
    Thanks
  2. May 14, 2012 at 5:32 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    My4X4Tacoma,
    A topper will only get you a fractional gain in mileage at best. If you have other needs for a topper, great, but do not spend $1500 for a topper expecting huge gas savings.
  3. May 14, 2012 at 5:34 PM
    '13 Ford F-150 SCREW
    F-150 Mod
    No change or possible slight increase on the highway and slight potential drop in MPG's in the city just due to the added weight that you need to get going off the start. If you get a shell with a roof rack, that could create more drag and affect your highway MPGs. I agree with Wolftree, don't buy a shell just for MPGs.
  4. May 14, 2012 at 5:36 PM
    My4x4Tacoma
    I dont expect any gain in gas mileage, but would be very happy if it helped. I really want the topper for the covered space and for the hunting dog.
    I am more concerned that the topper might have a negative impact on the gas mileage. But hopefully not much.
  5. May 14, 2012 at 6:00 PM
    wolftree
    Rick
    Ohio
    It should make very little difference in milage really. As you are planning on hauling your dog, be sure to get operating windows and vents.
  6. May 14, 2012 at 10:00 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    It is my understanding that a larger flat rear surface (tailgate+topper) will create more drag than just tailgate (tonneau cover).
    The optimal shaped topper for fuel efficiency would slant from the back of the cab gradually down to the top of the tailgate.
    Therefore, topper = theoretical loss and tonneau = theoretical gain
    However, if you're not going racecar speeds the difference will be negligable. If you lose .3 mpg or something but gain functionality/something you need/a warm spot for the pups there is really no reason not to get one. Just wanted to clarify that everything I've read/researched from ecomodders etc has pointed to a topper equalling a minor theoretical loss.
    You can easily counter that with a number of other things
