Topping off the tank?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paul123, Aug 27, 2016.
  1. Aug 27, 2016 at 8:44 AM
    Paul123
    Paul123 [OP] Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Usually when I fill up at the pump I just go until the handle clicks then stop. I'm usually able to put in about 16-17 gallons and drive 280 miles. Last time I filled it up waited until the click, then slowly kept stuffing gas in and was able to squeeze in an extra 3 gallons! So I put in a total of 19.5 gallons. This was right when the gas light came on, which is when I always fill up. Will doing this every fill up harm anything? I like the extra range 3 gallons offers.
    Hawk1 likes this.
  2. Aug 27, 2016 at 8:46 AM
    medic2230
    Murph
    Bama! Roll Tide
    Done this just about every time with my 1st gen and 2nd gen. Never had an issue.
    Hawk1 likes this.
  3. Aug 27, 2016 at 8:50 AM
    Paul123
    Paul
    Reno
    Kewl, the only reason I ask is because I used to do it on my 2003 Silverado. The emissions system started going bad at around 200k and the mechanics we took it too blamed it on topping off the tank.
    Rambo MARINE Recon likes this.
  4. Aug 27, 2016 at 8:50 AM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    It may and will harm the emission Canister that holds charcoal filter and may cause problems down the road,Dont overfill, when handle stops ,you stop and remove! Too expensive to repair and diagnose and don't want to break down and be stranded because of Emmision Products and parts damages!
    OffroadToy and Paul123[OP] like this.
  5. Aug 27, 2016 at 8:50 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    There's some kind of valve or sensor in the neck that can get damaged from topping off.
    I don't remember all the info. I top off anyway.
    Hawk1 and digitaLbraVo like this.
  6. Aug 27, 2016 at 8:52 AM
    T4RFTMFW
    This was it.
    digitaLbraVo and Paul123[OP] like this.
  7. Aug 27, 2016 at 8:57 AM
    medic2230
    Murph
    Bama! Roll Tide
    Yup this. I don't fill to the top where fuel is showing though. Don't recall ever adding 3 gallons more though. Maybe a gallon or so to get it to an even amount.
    T4RFTMFW[QUOTED] likes this.
  8. Aug 27, 2016 at 9:00 AM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    you can damage the charcoal canister. Thats how toyota "fixed" my CEL. they also replaced the gas cap...waste of money. I still add more after it shuts off bc this is the first time I have ever had the link drawn to topping off leading to the charcoal canister. I add roughly only a dollar and some change extra though, not 3 gallons worth! that may be a bit much?
  9. Aug 27, 2016 at 9:05 AM
    T4RFTMFW
    Yeah. When I say I top off, I mean I squeeze an extra 1/2 gallon or so.
    3 is probably the break stuff amount.
  10. Aug 27, 2016 at 9:17 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ good advice. Where I get gas the attendant topped mine off... ended up throwing a code and cost me around $100 at the stealership to diagnosis. Continuous topping off will damage the charcoal filter... big bucks to replace!
  11. Aug 27, 2016 at 9:21 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    This why I don't do it. Don't know if it's true or not but why take a change - emission repairs are expensive $$
  12. Aug 27, 2016 at 9:23 AM
    george3
    New Jersey
    "you can damage the charcoal canister" That's what I've heard 2
  13. Aug 27, 2016 at 9:24 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I just read an article (cant seem to find it)
    that said to NEVER top off a gas tank.
    Im sure a report has been published online somewhere.
  14. Aug 27, 2016 at 9:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This has always been a highly debated topic ( along with frequency of oil changes, Dino vs synthetic oil, which gas octane to use, What tire psi should be run, should you use ketchup or catsup, etc).
    At the end of the day, there really isn't a right or wrong answer, just a wrongfully right answer or a rightfully wrong answer.
  15. Aug 27, 2016 at 9:50 AM
    T4RFTMFW
    Useless post level: expert
    TheFang, digitaLbraVo and Paul123[OP] like this.
  16. Aug 27, 2016 at 2:15 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    There is a vent line that runs from the fuel tank, to the charcoal canister, to your intake. The charcoal canister is there to scrub the air of any hydrocarbons from the off gassing fumes by the fuel for emissions. If you over fill to the point that fuel enters the vent line, you will end up with liquid fuel in the charcoal canister. The charcoal cannot scrub liquid fuel, and therefore hydrocarbons escape out the other side of the canister. Sensors detect this and throw codes. If it is only a very small amount, the canister might dry out though its life will be reduced. If it is significant, or repetitive, the charcoal will become saturated and have to be replace with a new canister.
    You can top off without doing so to the extent of having fuel enter the vent line, but there is no way of knowing how much, which is why it is recommended not to do so at all. I usually put a few extra squeezes in there and have never had problems. Try to put anything significant in and your charcoal canister will be toast.
    Jimmyh, chunt5, Kyitty and 1 other person like this.
  17. Aug 27, 2016 at 3:01 PM
    george3
    New Jersey
    Thanks for the in-depth answer
  18. Aug 27, 2016 at 3:43 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I always just let it click off, let it sit for 30 secs or so, then grab one more handle full till it clicks again. 1. to avoid too much top off, and 2. for consistency with MPG tracking
  19. Aug 27, 2016 at 3:56 PM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    I always add a bit more after the click to round off the amount.(still uses cash,lol)
    I had a KIA beater car a few years back and I did indeed damage the charcoal evap deal by overfilling.
  20. Aug 28, 2016 at 7:07 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, actually there is only one correct answer. If you top off the tank enough to get Liquid Fuel into the evaporative emissions system it Will screw up the charcoal canister.
    crashnburn80 likes this.
