torch offroad lift help
Discussion in '5 Lug' started by xitsjacob, Feb 24, 2024.
  1. Feb 24, 2024 at 5:31 PM
    xitsjacob
    xitsjacob [OP] 98 2.4 Taco
    HTX
    I am working on installing a front 2 inch lift spacer we got the spring off. We have a spring compressor and still struggling to get the spacer in spring back on. For some reason you have pressure on where the shock rests at the bottom, so you have to push it down and then try and shove the spring up in the place with the compressor on.
  2. Feb 24, 2024 at 8:45 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    So I'm a 2nd gen but if there's any sway bars or shocks still attached I'd unbolt them temporarily. Sometime I've even seen the lower lossened but it'll obviously mess with the alignment ( which you'll need anyways after)
    xitsjacob[OP] likes this.
  3. Mar 3, 2024 at 2:47 PM
    xitsjacob
    HTX
    big help thanks
    5 Lug Fury[QUOTED] likes this.
