TORE C/V BOOT!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 92dlxman, Mar 16, 2013.
  1. Mar 16, 2013 at 5:44 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Its necessary to remove the bearings off the tripod to remove the tripod itself..the bearings pop right off with a little pressure and pop right back on..
  2. Mar 16, 2013 at 5:52 PM
    92dlxman
    92dlxman [OP] drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    cool, makes sense. now the last thing, i dont have the special clamp tool, would worm drive hose clamps cause any balance issues? even if i tried to be smart in my redneckness and offset them?
  3. Mar 16, 2013 at 5:56 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    :censored:
    I know my truck can handle more, but I also know my wallet can't handle anything breaking :(
    That'll change after I start at Rebel Off Road on Wednesday ;)
  4. Mar 16, 2013 at 5:57 PM
    MonkeyProof
    SoCal- SGV
    I have been using those clamps for a few years now with no problem. I would suggest in buying a box of latex gloves and a spray can of brake clean/parts wash from autozone, pepboys, etc etc. CV grease is stupid messy and gets everywhere. Also look up CV boot mod and do that as well
  5. Mar 16, 2013 at 6:01 PM
    92dlxman
    Kevin
    Visalia, CA
    thank you sooooo much. parts are being ordered. i appreciate everyones input on this.
    hopefully ill have a writeup in a couple weeks so some other poor sap such as myself doesn't spend all day on the same delimma. i have a shower to fix. cheers fellers
  6. Mar 16, 2013 at 6:03 PM
    MonkeyProof
    SoCal- SGV
  7. Mar 16, 2013 at 6:07 PM
    MonkeyProof
    SoCal- SGV
    They do but are meant to be a temporary solution and not a permanent fix.
  8. Mar 16, 2013 at 7:32 PM
    92dlxman
    Kevin
    Visalia, CA
  9. Mar 16, 2013 at 7:46 PM
    92dlxman
    Kevin
    Visalia, CA
    i appreciate the input. i had no idea that toyota even offered them
  10. Mar 17, 2013 at 1:38 AM
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    How often do these crap out??? What would cause it a lift kit??? Not something I would have the patenice to fix I think. What mileage should I look at them. I'm just short of 17k on mine
  11. Mar 17, 2013 at 2:10 AM
    The Traveler
    SoCal
    Look at the angles on your CV shafts. If the boot fins are touching anywhere on the boot, then they will be rubbing when you're driving, effectively causing wear on them and eventually causing them to tear. Since a suspension lift will raise the front diff, the angles will be more steep, causing the fins to get closer.
    Just keep an eye on them. If you're at stock height, they shouldn't be rubbing. After a lift, good idea to keep an eye on them fins once in a while to check for any signs of rubbing.
  12. Mar 17, 2013 at 2:30 AM
    415tacoma
    415tacoma Well-Known Member
    Woodacre, ca
    08 TRD Sport Debadged
    if you end up going after market go with napa, i replaced both mine when they both tore and i want to say it was $90 per c/v but the good news is they come with a life time warranty so if even the boot rips napa will replace the whole thing for free.
  13. Mar 17, 2013 at 7:54 AM
    lpfm1990
    Brian
    Newfane NY
    trd duals
    Right now it's 100% stock. How much do they rub with about a 2" front lift (884's with 5100's I'm thinking of doing)
  14. Mar 17, 2013 at 8:29 AM
    MonkeyProof
    SoCal- SGV
    Or you can look up and do the CV boot mod..spread those fins out some and not worry about rubbing :cookiemonster:
  15. Mar 17, 2013 at 10:28 AM
    #35
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Just wanted to let you know the Cardone halfshafts are a good axle. We use them all the time at the garage where I work. Never had one blow apart yet. It is the same axle you will get from Advance, Autozone, or almost any other auto parts store. Rockauto.com has about the best price for them
  16. Mar 17, 2013 at 11:15 AM
    #36
    The Traveler
    SoCal
    This...one of my first mods.
    :thumbsup: like I said, I've gone wheeling through mud, sand, dirt, rocks, and every day driving with my friend's Taco that has one of these. Nothing short of satisfactory.
  17. Mar 22, 2013 at 5:50 PM
    #37
    92dlxman
    Kevin
    Visalia, CA
    so the black grease goes to the outer joint and the brown grease goes to the inner correct?? ill be starting this tomorrow!
  18. Mar 22, 2013 at 10:15 PM
    #38
    MonkeyProof
    SoCal- SGV
    Yeah, that's how it goes.. I have more picks of my CV's broken down if you need picks for reference before you start. Don't forget the get latex gloves :p
  19. Mar 22, 2013 at 10:36 PM
    #39
    92dlxman
    Kevin
    Visalia, CA
    you sir, are a scholar and a saint. your help is much appreciated. couldn't have gotten the balls to do it without your input.
    early last minute run tomorrow will be, gloves, more lacquer thinner/brake cleaner, a 35mm socket (wish they would have stuck with the old 54mm), and some nice hose clamps if i cant find the tool to crimp the factory ones. my ecgs bushing came in so ill be doing that also. . . .better check how much gear oil i have in the garage. shoot might as well do all the gear oils. and im almost due for a coolant change, might as well do the t-stat. eff it the pump too, wonder how that radiator caps doing. . . . there i go again, ramblin and emptying the wallet. . . . . crap
  20. Mar 22, 2013 at 10:53 PM
    #40
    MonkeyProof
    SoCal- SGV
    Add extra cotter pins to your list in case you mangle one while trying to remove it from the half shaft..
