Torn ball joint sleeve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neryl, May 19, 2025.
  1. May 19, 2025 at 3:43 PM
    neryl
    neryl [OP] Member
    Hello folks, recently I changed my ball joints on the lower control arms. I've used the mevotech TTX. They are greaseable so I pumped a little in the driver's side. Old grease started to come out perfect I stopped. I did the same at the passenger but this time no grease came out. I was like what the hell is my grease gun empty? I pumped couple more times. No grease coming out but I found out with horror that the sleeve is swollen like a balloon. I was hoping when I start moving with the vehicle the release valve would release all the grease. Unfortunately didn't happened and the sleeve broke.
    My question is how long can I be driving before it needs to be changed? I have a new one but I don't have time to change it. I can get to it probably next month. They say broken sleeve leads to the ball joint wearing out prematurely but how quick is prematurely?
    Thanks!
  2. May 21, 2025 at 7:50 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    There is no objective lifespan and no guarantees. Depends on the abuse you put it through and what contaminants get inside. Like if you do desert runs where sand gets everywhere they will not last as long as driving on dry pavement. The answer is and will always be "as soon as possible".
    That being said, adding new grease after each drive will, in theory, give you more time by pushing out contaminants. Or at least after any wet/dusty/muddy drives. And try to avoid getting water inside from the carwash. If you are just daily driving it to work and back, I can't see why it wouldn't last a month.
    Naveronski likes this.
  3. May 21, 2025 at 8:01 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I agree with the other poster; a month "should" be fine.
    If you're driving in nasty mud, blowing sand, or salted roads of the great north you might have issues.
    Commuting on normal pavement? Should be fine for quite a while, tbh.
  4. May 21, 2025 at 8:20 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You can keep running it like this indefinitely if you pump new grease in every month or so.
    Chuy likes this.
  5. May 21, 2025 at 8:41 AM
    neryl
    neryl [OP] Member
    Thanks guys! That's all I needed to hear haha! I'm planning a week long roadtrip that's why I was worried. I have a new ball joint ready I just don't have time to do it before the trip. Thanks again!
  6. May 21, 2025 at 8:50 AM
    DavesSR5
    DavesSR5 Well-Known Member
    Dave
    North of Nashville, TN
    2023 SR5 DCSB RWD AT Barcelona Red (12,130 miles when bought)
    LED Bed lights, gas cap holder, MA1 W/ 90 degree connector, Drop Step Running Boards, Console Tray (Red Trim), Cup Holder Insert Kit (Red Trim), Head Rest Hooks, LED interior lights, Dog Hammock, rear door protectors, LED reverse lights (now VTAILs), black tailgate inserts, blackout badging, color matched glovebox letter inserts, VTAILS, H9 low beams, LED tag lights, bed mat, tailgate mat, Tri-fold soft Tonneau cover, Pro grill (OEM),
    Tech Tip: You don't need to add grease once the boot starts to swell a little, generally if you can squeeze the boot and feel grease squishing in it, it has more than plenty in it... Meaning, you don't need to pump until you see old grease come out...
    Safe travels...
  7. May 21, 2025 at 9:00 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    I have seen Youtube videos of guys using a hyperdemic needle-like tool to inject either oil, or wd-40, through and into the ball joint rubber-dust-dirt bag. They swear by it. Just saying.
  8. May 21, 2025 at 9:24 AM
    DavesSR5
    Dave
    That is a way to get grease into the boot for parts that did not come with zerk fitting... Although it does not grease the ball and socket correctly like a zerk fitting will being it adds grease to the boot area, but the grease needs to come in the ball socket cup in order to properly lube the ball and socket...
    Chuy and thomasburk[QUOTED] like this.
  9. May 21, 2025 at 9:28 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB
    Nice project btw. I heard that it's a good idea to change them out every 100k miles, or as needed. Were yours giving you issues?
  10. May 21, 2025 at 3:21 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    This may sound counterintuitive, but I agree with it. The boot just keeps the grease from dripping out and contaminates from collecting inside. No force is going to cause said contaminates from working their way into the joint except water. I would clean off the boot and apply silicone to seal it.
