Torn between 2 Canopies... Snugtop and Leer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BCTaco, Feb 9, 2013.
  1. Feb 10, 2013 at 3:28 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    It allows you to clean the windows in-between the cab and canopy. I've read where the "boot" will wear through paint over time.
  2. Feb 10, 2013 at 6:35 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    The boot doesn't prevent cleaning the cab window. I like the boot myself.
    The boot is the better setup, because you have a seal between the cap and the cab, it gives you the option of removing the cab window and still have a good seal between cap and cab. I guess I'm old school.
    I like to remove the cab rear window on some trips to let people move between the cab and the cap. Hell, it only takes 20 minutes to remove and reinstall the cab rear window. You can even do it by yourself with the slider.
    That narrow 3-pane slider on the Gen II sucks BTW, can't fit a good-sized kid or dog through it from cap to cab. Hence why the boot and removing the cab window is ok with me. The removeable slider seems like a waste of money. Ah well, to each his own I guess.
  3. Feb 10, 2013 at 9:48 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I believe with the 100XR, you have the option of a remote controlled release for the rear hatch. I bought the 100R, with the old school rear window. I do find myself wishing it had remote hatch release on it.
  4. Feb 10, 2013 at 9:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Boot destroys paint.
    They used to sell a "boot guard" clear plastic film to put on before the shell. Instead of the boot chaffing the paint off, the film seemed to do something to intensify the UV effect of the sun.......burned the paint black on one truck I had.
    But I will say the boot was nice, functionally. I used to leave the side windows on the shell open, the rear cab window open, and had flow through ventilation.
    My shell has the front window. While it was on order, the LEER dealer loaned me a shell that had the front boot on it. The boot did not fit right around the rear brake light on the cab. It leaked very badly. I did not have that problem with my previous truck with the booted shell. I don't know if it was just that particular shell that had an issue, or if all the boots don't fit right. I would get a guarantee before ordering a LEER with a boot.
  5. Feb 11, 2013 at 7:58 PM
    BCTaco
    BCTaco [OP] Member
    Don
    Langley BC Canada
    2012 TRD Off Road
    165lbs. Should I get something more heavy duty ? Max load on top of the canopy is apparently 500.
  6. Feb 11, 2013 at 8:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    So the rack is rated at 165 lbs while the roof can handle 500 lbs ?
  7. Feb 11, 2013 at 8:04 PM
    BCTaco
    BCTaco [OP] Member
    Don
    Langley BC Canada
    2012 TRD Off Road
    Correct.
  8. Feb 11, 2013 at 8:47 PM
    OZ-T
    Peter North
    British Columbia
    I think I would be wanting to get a higher rated rack so you could take advantage of your roof rating
    My rack is rated at 400 lbs , and I know from experience moving lumber , it doesn't take much to get to that type of weight
  9. Feb 12, 2013 at 7:41 PM
    BCTaco
    BCTaco [OP] Member
    Don
    Langley BC Canada
    2012 TRD Off Road
    Just put my order in for the Snug :). Can't wait, apparently it will take a month, but I feel like I made the right decision. Thanks everyone for your input :).
  10. Feb 12, 2013 at 7:45 PM
    OZ-T
    Peter North
    British Columbia
  11. Feb 12, 2013 at 8:59 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Good choice. You will be happy.
  12. Feb 14, 2013 at 2:03 PM
    ASH
    ASH Well-Known Member
    SF Bay Area, CA
    2010 DC PreRunner TRD Off Road
    SnugTop Rebel Shell, Bilstein 5100's @ 1.75, Rear TSB, BFG A/T KO 265/75/16, Tranny TSB, WeatherTech Digital Fit Floor Mats, Debadged (Sides), Black Badges (Tailgate), Avid Off Road Sliders, TRD Shoulder Pads, Factory Color-Matched Grille w/Blacked-Out Emblem
    I've got the Rebel. When compared with the Leer models side by side, SnugTop had the better fit and finish IMO.
