Torn CV Boot,How far can you drive before replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lynlan1819, Apr 30, 2017.
  1. May 13, 2018 at 10:26 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    If anyone wants to reboot you can get a replacement kit from Toyota. It will come with the correct packets of grease for the inner and outer joints. Often they use different grease for each. And the kit will include the boot clamps. You may need a special plier tool to clamp the clamp tight depending on the type of clamp. And the boots may be better than aftermarket boots.
    The grease can be messy. Wear disposable gloves, wipe as much grease off as possible with paper towels, then repeated hit it with brake cleaner until it's clean or soak it in a solvent. Then let it dry or use compressed air to dry it.
    I totally understand why someone would prefer to just replace the axle with a rebuild and be done, but some of us like to tear things apart and fix them even if it seems like a waste of time to others.
  2. May 13, 2018 at 10:27 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    $35 for an oem boot and clamp kit with grease and new snap rings. All you need at that point is an hour of time. Might not be worth it for those that struggle to hold a wrench I guess.
  3. May 13, 2018 at 10:37 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    https://toyotaparts.bochtoyotasouth.com/oem-parts/toyota-axle-assembly-4343004070/
    About $310 for an OEM axle. Might seem like a lot for some. My truck is over 10 years old now, lifted for 9 of those years. The inner boot on one of my axles has been torn for at least 3 years. It's been exposed to New England winters (lots of salt), water, mud, sand, etc... It's still going strong. When the time comes to finally replace it, I'll gladly spend the $300+ for an axle that will be good for another decade.
  4. May 13, 2018 at 10:37 AM
    Buckaroo1993
    Buckaroo1993 Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    The shafts I am referring to are new, not remanned.
  5. May 13, 2018 at 10:43 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    :anonymous:
    Guilty.
  6. Jun 16, 2018 at 7:11 PM
    tacothyme
    tacothyme Well-Known Member
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
    Yeah my boot on the passenger side in my '05 just tore today. Wrapped some duct tape around it and gonna hope for the best! Should be fine - vehicle never sees dirt roads or mud.
