Torn Cv boot question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hops, May 26, 2011.
  1. May 26, 2011 at 7:34 AM
    Hops
    Hops [OP] Well-Known Member
    Gabe
    south mississippi
    08 Silver Streak Mica Access Cab 4X4
    Shock and leaf spring TSB, Neoprene seat covers, weathertech digital fit floor mats, vent visors, bug shield, secondary filter removed, K&N drop-in filter, century camper shell, 265/75R16 ATM's...
    I tore and need to replace the outboard cv boot on the passenger side of my '08. Do i have to remove the axle? Or can i get to it just by taking off the hub?
  2. May 26, 2011 at 7:39 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You don't want to just replace the boot just replace the whole axle the boot is a PITA!
  3. May 26, 2011 at 9:36 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    agreed with jlee. did it once and never will do it ever again.
  4. May 26, 2011 at 9:39 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Yep, 40 some buck plus shipping from Rockauto......that's a brand new half-shaft too
  5. May 26, 2011 at 11:43 AM
    Hops
    Gabe
    south mississippi
    I understand that its difficult but i have a pretty nice shop at my disposal, all the necessary tools (35 mm socket and t55 torx etc.) plus new cv boots. And a dad who is a 50+ year mechanic to help. I know rock auto has cardone axles for cheap but i need the truck tomorrow so that is out of the question. What i need to know is can you change the outer boot without removing the axle.
  6. May 26, 2011 at 11:53 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Technically, yeah. But the hub still has to come off and it will be a bitch to seprate the CV with the axle still in the diff. However, once it is to that point the only thing left to do is pry the other end out of the diff and you could change it on the bench.
  7. May 26, 2011 at 11:54 AM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    I'm thinking about getting a lifted 4x4, how much lift you have and was that the reason for your cv boot tear?
  8. May 26, 2011 at 12:02 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    its easier to just pop the axle out and clamp it in a vise and replace the boot. at my work we give the customer the option, reboot(less parts, more labor) or new axle, (more parts, less labor).
  9. May 26, 2011 at 12:08 PM
    oldstick
    oldstick Middle Age Member
    GA
    How long has the boot been torn? A pretty good mechanic told me once the boot is torn for a while, you really don't know what all dirt has gotten in there, so a lot simpler to just replace the whole thing for $40.
  10. May 26, 2011 at 12:34 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ^^^^ yup, dirt and water
  11. May 26, 2011 at 1:12 PM
    Hops
    Gabe
    south mississippi
    zero lift, i went down an old logging road and a stick tore a 4 inch gash in the right outboard boot.
  12. May 26, 2011 at 1:15 PM
    Hops
    Gabe
    south mississippi
    I tore the boot yesterday, noticed it before even half the grease slung out then drove home 20 miles on pavement parked the truck at my shop took off the wheel and pressure washed the grease off. Haven't touched it since. Also, i have a boot kit in my hand right now, i would have to order the axle from rock auto and i need the truck tomorrow really bad.
  13. May 26, 2011 at 1:17 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Fwiw you can drive round on a torn boot for a while. I drove on mine for at least two months with no issues
  14. May 26, 2011 at 1:20 PM
    Hops
    Gabe
    south mississippi
    This is basically what i need to know, thanks
  15. May 26, 2011 at 1:21 PM
    Hops
    Gabe
    south mississippi
    Im selling it Tuesday so that wont work.
  16. May 26, 2011 at 9:51 PM
    JLee
    Jerry
    Bay Area NorCal
    Changing the boot on the truck is just going to be more of a pain. If you really want to change the boot remove the axle and change it then put the axle back on the truck.
