Tornado fuel saver question
Discussion in 'Performance and Tuning' started by Lukeduplesse, Aug 3, 2010.
  1. Aug 3, 2010 at 10:35 PM
    Lukeduplesse
    Lukeduplesse [OP] Well-Known Member
    Long Beach
    2000 Supercharged PreRunner
    Has anyone used the "Tornado" fuel saver and actually seen a improvement?
  2. Aug 3, 2010 at 10:36 PM
    YeahYeah
    YeahYeah Well-Known Member
    Thomas
    (My Home - Murrieta, CA) Now, Alexandria, VA
    07 Tacoma Pre-Runner
    mud flaps gone, second air-filter gone, DTRL, fog light whenever and work with hi-beams, cut exhaust (was wicked flow), flat black stock rims, ABS switch, cup holder led's (with switch), turning signal mod #45, Bilstien 5100's, grill mesh
    eh.... little.
  3. Aug 3, 2010 at 11:08 PM
    Lukeduplesse
    Long Beach
    so its not worth the 60 bucks?
  4. Aug 3, 2010 at 11:11 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    I have no experience with one but everything I read and hear say it's a gimmick.
  5. Aug 4, 2010 at 12:02 AM
    Hambone805
    Hambone805 Well-Known Member
    Aaron
    San Diego, California
    2015 4x4 Tacoma TRD
    STOCK :(
    why don't you just give me the 60 bucks
  6. Aug 4, 2010 at 5:11 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If a cheap piece of metal improved gas milage, toyota would have added it to the 2nd gen.
  7. Aug 4, 2010 at 11:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its a gimmick. I dynoed one on a 3.4, and it lost about 4 hp.
  8. Aug 4, 2010 at 11:37 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    $60 and it DECREASES my horsepower....ehh...no thanks!
    I'd spend $60 on a cheap piece of metal if it INCREASED my HP by 4. Even if I used more gas :crapstorm:
  9. Aug 4, 2010 at 11:40 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I tried one years ago that someone gave me for free... and it helped improve mpg slightly in my opinion because it cloggs up the intake hose which limits the amount of air that can be consumed by the engine meaning less gas..thus more miles on less gas and a loss of hp. (sorry for the run on sentence)
    You could probably kinked the intake hose and get the same results if you never floored the gas. Sorta tricks the MAF sensor??
  10. Aug 4, 2010 at 11:44 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    A buddy had one on a 350 chevy it didn't do him any good. I then used it on my 454 and noticed jack shit, so it back because I didn't want it taking up space at my house.
  11. Aug 4, 2010 at 11:50 AM
    kristonex
    kristonex Well-Known Member
    Maryland soon to be Denver
    2010 SR5 Access 4x4
    Debadged tailgate - Limo tinted windows - Sockmonkey bed decals - Fully custom upgraded stereo 9 speakers w/custom built subwoofer box 1200 watts total power - swapped white and blue LED gauges - integrated backup camera - removed front mud flaps - All interior lights swapped with LEDS
    The old saying "if its too good to be true it probably is" definitely applies here. There is no miracle gas saver or everybody would be using it.
  12. Aug 4, 2010 at 9:45 PM
    Lukeduplesse
    Long Beach
    Thanks everyone for all your input. I'm glad I asked first before I threw away a tank of gas.
  13. Jul 29, 2011 at 5:43 PM
    Yota64
    Yota64 Professional Threadjacker
    Does this mean a performance air intake would use MORE gas?
  14. Jul 29, 2011 at 5:49 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Claims of better mpg's because of an intake mod are bs. Flow more air, the ECU will inject more fuel. Claims of more HP? Yes, but marginally so.
    The only proven way to save gas is to keep your tires inflated properly, keep your tailgate up, keep your windows closed, and keep the lead out of your foot!
  15. Jul 29, 2011 at 7:03 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Basically all it does is take up space, cause erratic air flow, and steal your money. Want better mpg's change your driving habits and keep up with maintenance.
  16. Jul 30, 2011 at 1:01 PM
    Yota64
    Thanks
