Torque converter 250 degrees when towing
Discussion in 'Tundras' started by 15Tundra4.6, May 24, 2021.
  1. May 24, 2021 at 9:44 PM
    15Tundra4.6
    15Tundra4.6 [OP] New Member
    T
    2015 Tundra 4.y
    Aftermarket cooler and k&n
    So I've been trying to figure this out for a while now I got my 4.6 2015 tundra and I'm pulling a 5200 lb toy hauler with a couple ATVs and when I'm going uphill if I'm not in 4th gear my torque converter gets up to 250° my oil temperature 219 which isn't bad and they say that these transmissions are supposed to run at a warm transmission fluid temperature to thin it out but with my torque converter getting that hot should I be worried and what do you think I could do to fix that I have a aftermarket transmission cooler with fan that only seems to help when I'm stopped.
  2. May 24, 2021 at 9:51 PM
    Bishop84
    Bishop84 Well-Known Member
    Manual says 4th S mode, and 65 mph is ideal. There's not much else you really can do except make sure the trailer bearings and brakes are in good order.
  3. May 26, 2021 at 8:52 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Does your truck come with a towing package with factory installed trans coolers?
  4. Oct 7, 2021 at 5:12 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    You can always drop it into a lower gear to cool the transmission down. Heat is produced at the torque converter vs the rest of the transmission.
  5. Oct 7, 2021 at 5:21 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You can slow down. Check a trans fluid temperature vs life span chart. ~220F you are starting to eat into the fluids lifetime.
  6. Oct 29, 2021 at 4:03 AM
    gearcruncher
    Canadain bumper technician
    Anytime the converter is out of lock up , you are creating an abundant amount of heat . Throw a transmission cooler at the truck and as mentioned above , use 4th gear to keep the clutch inside the torque converter locked up . If you have a scan gauge , you can see when your converter locks and unlocks
