Torque Converter and Tranny going Bad - Maybe
Discussion in 'New Members' started by zeppyman, May 28, 2013.
  1. May 28, 2013 at 3:18 PM
    zeppyman
    zeppyman [OP] New Member
    jim
    Orlando
    09 aTacoma truck
    Hello and Help please.
    Have a 2009 Dbl Cab Tacoma with 107,000 miles on it.
    Have a vibration at 38 to 42 mph...nice little shake sounds like it is coming from the front. It gets amplified if your going up a grade and hold at that 40 plus or minus speed.
    Took it into the dealer finally and they determined it was a Cam Gear as they got a code for it. They replace it and still there.
    Next they tried replacing drive shaft and u joints. Yes, still there and so they put back on the old drive shaft and Us.
    Finally, it was determined to be the Torque Converter....and later the next day they added the Transmission. They replaced both and you got it....problem still there but better they said.
    Diagnosis: The Torque Converter had went bad and it cause the transmission to be recommened to be replaced as well. Tranny runs fine as far as I can tell but they found aluminum metal shavings in the pan and said it the Tranny was corrupted...would go in time. Now there searching for what is making even the new Torque Converter do what the old one did. They believe it is the computer sending a wrong signal and the clutch or fly wheel is not engaging at 40 mph. I don't fully understand the mechanics behind it all. All I know there still looking for the causitive problem and I am waiting to be told next I have a bad computer.
    Gentlemen, I am at a loss and surely don't want to pay for a new tranny when perhaps it was not necessary. Could it be somthing simple like a strut or something. Oh yeah, forgot they replaced one broken engine mount but that was not it.
    Could it be the Rear Diff?
    If it turns out be the rear diff or anything else not capable of directly effecting the performance of the torque converter then all these repairs mostly have been perhaps in vain.
    I could sure use some help. They have the truck for another day or two and I want to be prepared to discusss what they report back to me. Also, IF whether or not I have paid for a New Transmission and Torque C. unnecessarly. Not saying I have but I need to feel comforable the repairs made have been fair.
    Thank you.
    Jim
  2. May 29, 2013 at 7:04 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Welcome
  3. May 29, 2013 at 7:06 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    next time it occures put it in 4wd and see if it goes away.
  4. Jan 12, 2014 at 6:52 PM
    jrowe4321
    jrowe4321 Active Member
    Justin
    Los Angeles
    09 prerunner access cab
    did you ever figure out what the problem was? My truck is making the same exact vibration and i took it to toyota a week ago and theyve been trying to fix it for 2 weeks. They put a new driveshaft in last week and it didnt change anything and they are putting a new transmission in tommorow. It was the weirdest thing, both mine and my friends tacoma started the weird vibration around the same time..
  5. Apr 28, 2014 at 10:32 AM
    TX Tacoma
    TX Tacoma Fightin Texas Aggie
    Arlington, TX
    Did you ever definitively figure out your issue?
    I have a 2009 PreRunner Dbl Cab 4.0L with 95K miles. Just started having similar situation vibrations at 22-25mph, 32-35mph, and 40-43mph, usually at 1500rpm, while under load (accelerating) and gets worse if I'm driving up an incline.
    Have done the following:
    New tires (balanced of course)
    New u joints (all 3)
    Transmission flush and new filter
    New spark plugs
    I found nothing in the transmission pan to suggest anything other than usual wear (minimal grey sediment on magnets, no shavings).
    Truck still vibrates. I could believe a computer is telling the transmission something incorrect, but I'm open to other input as well.
    My truck has never suffered from the well documented vibrations that some tacomas seem to have from day one. I don't think this is anything like the carrier bearing or driveshaft having incorrect operating angles since this problem was nonexistent in the first 94,000 miles of driving. I think this is something that has gone bad and needs replacement, just don't know what yet.
    Thanks for any help.
  6. Apr 28, 2014 at 10:54 AM
    scottalot
    scottalot ...
    on TW
    2015 DCSB Offroad 4x4 MGM Love Machine
    Back Stock Again..Dakkars,305/70/16 MT's, Extended length Fox Coilovers, Fox RR rear Shocks, Total Chaos UCA's, Dakar Leaf packs, LED Map and Dome, Breather relocate, Slimer from Ghost-busters starut up screen, Vent Visors, LED Pod's on Ditch Brackets soon, Level 8 Strike 6 Wheels, New MT Tars - Fierce Attitude, SOS front bumper -steel, SOS bed rack, LED white marker lights, LED reverse, TRD exhaust, Wheelers Super Bumps up front, SOS sliders bolt on with fill plates, Csjummper2003 White/Amber DTRL and white parking led bulbs, RTT rack basket Sold 2013, sold 2014 Tacoma. All listed stuff was on the '14 Bed Mat, WeatherTech Rain Guards, Ultra Gauge, TW Sticker amongst others, Useless Free OEM Bug Deflector, Flyzeye, OME Kit with 885's and Dakar and Nitro Shocks front and Rear . Tailgate mod, SOS Concepts 1/4" Skid Plate, White LED's interior Dome and Maps, Goodyear Wrangler MTR Kevlar 275/70/17, Wet Okole Seat Covers - full piping in Charcoal Grey, Lamin-X Green Fog light film, 17"x8 -10 offset Level 8 MK6 wheels in Gun Metal Finish, SOS Concepts Sliders W/ Kickout 12/21/14, Stubby antenna, LED reverse lights, lift removed 2/20/15 - making changes and trying to make up my mind
    Looks like the OP hans't been back i a while. His profile says last log in was 6/2013.. Annoying as its always nice to get some feedback as the the end result..
  7. Apr 28, 2014 at 12:12 PM
    sportsfreak3122
    sportsfreak3122 New Member
    Arlington,WA
    sr5 trd
    I recently bought a 2002 Tacoma trd and was thinking about lifting it to put 35/9.5/16 on it any lift recomendations?
  8. Apr 28, 2014 at 12:17 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    starting your own thread or using the search feature might be a good place to start. :confused:
