Torque converter chatter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C1ph3r, Mar 23, 2014.
  1. Mar 24, 2014 at 7:55 PM
    C1ph3r
    C1ph3r [OP] Well-Known Member
    A.W.
    Concord NC
    Nothing special
    2014 DCSB 4x4 TRD OffRoad Super White TRD sport grill, Custom mesh grill, Tailgate theft mod, bed mat, tint, chopped antenna, 16x8 Konig Counter, Weathertech mats and window shades, Relentless Fabrication bolt on sliders
    thanks. after posting all over about the ultra gauge i found it wouldnt. kinda sucks since i already have it. oh well.
    I will certainly let everyone know what the dealer says.
  2. Mar 25, 2014 at 5:17 AM
    gearcruncher
    Canadain bumper technician
    Considering the vehicle uses adaptive learning , why couldnt the OP disconnect the battery and re-teach the transmission to shift later or deeper into the throttle ? I know the trans uses pulse width modulation but a more agressive shift strategy may help with the early Tcc apply rate . I remember the days when you could buy a black box in the aftermarket to control the converter . It was a common install with the 700r4 . No Pwm mind you .
    The folks in the engineering dept at Toyota are making their customers suffer a lot of driveability issues in order to acheive an estimated better fuel economy . Does locking or partially locking the converter this early really save that much fuel ? Can you imagine what a set of main journal bearings look like after lagging an engine for 150,000 miles ?
  3. Mar 25, 2014 at 6:48 AM
    BamaToy1997
    Bill
    Navarre, FL
    I am a little curious on that loaner. My sister has a new (reasonably) Camry, and I thought all of them had the same transmission hers is, which is a CVT transmission that doesn't actually shift gears. Of course it does have a TCC, so it could still have that shudder.
    Good point on the adaptive learning. The question would be if the TCM uses volatile memory or EEPROM memory for the adaptive learning.
    Yeah, I remember the same days with the 700R4. As soon as they redesigned to the 4L60E, PWM came into light. I like the PWM system myself, and think it is great. But Toyota can't tell us that they can't work out a new algorithm for theirs to fix this.
  4. Mar 25, 2014 at 7:26 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I just stumbled on this thread and thought I would share my experience. About 2 years ago I got the "rumble strip" feel in very low RPMs when the truck was in OD. It was violent, the whole dash would shake pretty bad. Right around 38-40MPH. I took it to the dealer, they troubleshot, even drove around in 4x4 w/o the rear driveshaft in to diagnose. They checked the transmission fluid and topped it off, and it was fine for another 2 years. Then it started again, same symptoms. Took it to the dealer again and they troubleshot A LOT. Even did a transmission fluid flush which did not resolve the issue. They questioned the 5100 Billys and AAL I have on the rear, but dismissed those and kept digging in. Finally they got approval to put in a re-manufactured transmission as they were suspecting something with the torque converter or clutch packs. It's been fine since, that was about 5 months ago.
    I have an '09 TRD Sport, Double Cab. 5100's on the front at 1.75", AAL in the rear, and 265/75/16 Duratracs now. Set of tires before that was 265/70/17 Dueller Revos.
  5. Mar 25, 2014 at 7:50 AM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    Don't beat yourself up - there isn't a dipstick on our trucks. Just a fill and a drain hole. With the tranny at operating temp (and truck off), pull the fill plug. If you get a little coming out, you're good to go. If you have to dip your finger in to find fluid, you're low and need to top it up.
  6. Mar 25, 2014 at 9:49 AM
    gearcruncher
    I beleive you need to check the fluid with the truck running . Thats the only time the transmission pump is turning . Checking the fluid with the truck off would give you a false reading or a very high level since the pump is not circulating transmission fluid . ;)
    Here is the tutorial http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
  7. Mar 25, 2014 at 11:47 AM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Sorry, whatever the case - look it up in the tranny fluid change sticky and go from there. :)
    Didn't want to give catastrophic advice and regret it, that's all. ;)
  8. Mar 25, 2014 at 5:31 PM
    C1ph3r
    A.W.
    Concord NC
    Nothing special
    so they couldn't find any problem. i took my service writer for a drive and he saw the issues and explained they actually see it in a lot of them. but since toyota hasn't admitted there is a problem they cant do anything. i asked them to please take a look at the fluid levels and they finally agreed to that. they are also going to try the TSB for the 2013 and see if that will work even though the 2014 doesn't actually have the TSB issued for it. we will see how it goes. At least they acknowledged there was an issue. but the dealership doesn't want to put any money in it to fix it if toyota isn't going to reimburse them. i also called and filled my second case with toyota.
  9. Jul 9, 2014 at 4:58 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    My 2011 does this.I bought it used with 20k on it.Around 20 mph and downshifting it shakes and feels a bit funny.Nothing devastating but in slow traffic you feel it and when coming to a stop and it's downshifting you also feel it.When accelerating I go through that band pretty quick.It is still there but not as pronounced.
    since I put an aal in it and 5100's I am going to try and shim the carrier bearing first.Cheap fix if I can get it to work.
  10. Jul 9, 2014 at 7:28 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    are you supposed to check levels at running temp or cold? and there anyway to change fluid yourself and not have to have the dealer do like i always have had to do?
  11. Jul 9, 2014 at 8:02 PM
    gearcruncher
    Did you read through this thread ?
    There are 2 links posted that show you how to check the fluid level at home :)
  12. Jul 10, 2014 at 3:01 PM
    TacoLlama
    R.I.
    2019 SR5 DCSB
    Yeah the carrier bearing drop didn't work for me.Made my angles worse and created a vibration at 60 mph. I greased my u-joints and returned the carrier back to it's stock position.On to my next theory......:frusty:
  13. Jan 26, 2021 at 5:59 AM
    GibbsTacoma
    GibbsTacoma Well-Known Member
    Charlotte Metro Area
    2010 Tacoma TRD Sport DCSB 2wd
    To the OP, I know this is a old ass thread but I have the same exact issue on my 2010. Did you ever resolve this? I'm going to check my transmission fluid level as well eventhough I had it changed last year.
  14. Jan 26, 2021 at 6:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not only that, he's not even logged in since Nov of 2016.
    GibbsTacoma[QUOTED] likes this.
  15. Jan 26, 2021 at 6:23 AM
    #35
    12TRDTacoma
    Rob
    Concordia
    Boosted
    HP Tuners.
    Screw Toyota and their crap-ass engine and transmission tuning on these trucks. The best way to fix these sort of issues is to just override it entirely by writing in a new set of values.
    Personally, I never experienced this issue and the sort of "chatter" I did was when the carrier bearing was failing and allowing the driveshaft to sloppily bounce up and down on hard acceleration. I went polyurethane and have never looked back since, then went HP Tuners and went even more aggressive on tuning across the board on nearly all values modifiable.
  16. Jan 26, 2021 at 6:48 AM
    #36
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    fluid level, and how clean it is, is my only input.
    my family had a mercury minivan that had a similar issue, we bought it like that with 160k miles. we ran it till 255k miles when it shreded itself. not like we cared, since it was 1500$.
    i will say my a340 paired with the 2.7 is a lot less picky than any of the 4.0 toyotas or 4.0 nissan autos which ive heard of.
    but thats a transmission older than my project truck.
    If you ever want any awesome transmission write ups check out anything @gearcruncher says in tons of threads. he knows his stuff.
  17. Jan 26, 2021 at 6:53 AM
    #37
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    I second this. my vibration wasn't quite as violent as some, but it was present and annoying. moving the TCC unlock values up so it unlocks at like ~1200 rpm instead of ~1000 rpm has virtually eliminated the vibe.
    Edit: and its well worth the money for the HP tuner and credits. Plus, once you have that, you can get a better engine tune for better feel/mpg. so its a definite win/win
  18. Jun 3, 2024 at 7:45 PM
    #38
    Greenbean10
    Greenbean10 Well-Known Member
    2010 Timber Mic 4x4
    So does this mean that your TC is working how it should if the shutter returns or does this mean that there is a TC problem?
  19. Jun 3, 2024 at 8:15 PM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Means the torque converter clutch is slipping and causing a shudder. Touching the brakes tells it to unlock so the feeling goes away and then comes back qhen cruising
    Some guys have had luck with a fluid additive, some have had to replace the torque converter
    Greenbean10[QUOTED] likes this.
  20. Jun 3, 2024 at 8:25 PM
    #40
    Greenbean10
    2010 Timber Mic 4x4
    If the brakes are tapped and then released, a non problematic TC shouldn’t shudder after letting off the brake and cruising? Asking because I need to test mine.
