Torque converter chatter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C1ph3r, Mar 23, 2014.
  1. Jun 3, 2024 at 8:36 PM
    #41
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It shouldn't shudder at all
    Tapping the brake is a way to determine what is shuddering. Because sometimes it could be something else like a drivehaft or slight engine misfire
    Greenbean10[QUOTED] likes this.
  2. Jun 3, 2024 at 9:00 PM
    #42
    Greenbean10
    Greenbean10 Well-Known Member
    2010 Timber Mic 4x4
    Gotcha. I was recently told that my entire rear driveshaft needed to be replaced because of a shudder starting from stop at low speeds and uphill.. so looking to get as much info as possible because I’m not believing that I could have damaged a driveshaft under normal driving conditions
  3. Jun 3, 2024 at 9:16 PM
    #43
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you feel shuddering everywhere all the time it's probably not the TC, likely something rotational/mechanical like the DS, wheel balance, etc
    TC shudder is usually light throttle while cruising at speeds over 30-40 mph or so. If you press the gas or brakes it should go away immediately
    Greenbean10 likes this.
  4. Jun 3, 2024 at 9:18 PM
    #44
    Greenbean10
    2010 Timber Mic 4x4
    That makes me feel a little better but… to be determine. Thanks for the info!
  5. Jun 3, 2024 at 9:54 PM
    #45
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I've never done it myself but guys will take the rear driveshaft out and drive around in 4wd (front wheel drive) to see if the vibration goes away
