Torque converter shutter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CheauxxYeauxx, Feb 16, 2017.
  1. Feb 16, 2017 at 1:11 PM
    CheauxxYeauxx
    CheauxxYeauxx [OP] Well-Known Member
    Cody
    Nuba, Louisiana
    2009 TRD sport 4x4
    6 inch pro comp lift with the factory installed TRD supercharger
    Has anyone replaced their torque converter on the truck? I've done everything beside this to find the vibrations in the trucks drive line
  2. Feb 16, 2017 at 1:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Your u joints and center bearing are solid?
  3. Feb 17, 2017 at 11:06 AM
    CheauxxYeauxx
    Cody
    Nuba, Louisiana
    2009 TRD sport 4x4
    Man dude I've changed everything, don't the new 8" clamshell from ECG and new u joints with hanger bearing and also have a whole new chunk, everything beside the torque converter it's the only thing I have found it could be
  4. Feb 17, 2017 at 11:34 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    what kind of driveline shutter do you have? I had a vibration from 25-30mph under light acceleration. When i flushed my trans fluid for fresh, it went away (also i believe i was 1-2 quarts low)
  5. Feb 20, 2017 at 1:13 PM
    CheauxxYeauxx
    Cody
    Nuba, Louisiana
    2009 TRD sport 4x4
    Same and I've flushed it twice in 16 months
  6. Jul 19, 2017 at 4:29 PM
    Lthompson
    Lthompson Well-Known Member
    ever find a fix? I have a vibe under load in all gears around 18-2300 rpm I'm fighting that I cant find much info on.
  7. Jul 19, 2017 at 5:13 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
  8. Jul 31, 2017 at 12:30 PM
    CheauxxYeauxx
    Cody
    Nuba, Louisiana
    2009 TRD sport 4x4
    Yea I ended up pulling the tranny putting a HD torque converter
  9. Jul 31, 2017 at 12:37 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Where from, what stall speed?
  10. Jul 31, 2017 at 12:42 PM
    Lthompson
    Can you describe a little bit what kind of vibration it was causing? Ive been to a transmission shop and took them for a drive, Been to the dealer and took em for a drive. Trans shop said it didn't seem trans related and I would be wasting my money to tear into it. Dealer said normal engine harmonics and maybe driveline vibes. , some are worse than others. I describe it as almost a hum, or like a cellphone vibrating. I get it around 17-2300 rpms the worst. Has nothing to do with speed or gear, its all influenced by rpm with load on it. Though I get the worst when in D at about 60 mph on a slight incline. Its like a drone sound with vibration just kicks in. I feel it everywhere. Steering wheel, pedals. Floor. My thoughts are it cannot be anything in the drive shaft because its not speed related.. If you shift into another gear, it stops.. Yet the speed and load on the shaft is exactly the same. Only thing changing is the rpms. Now, leave it in that gear, and let the rpms get back into that range, and it starts again. That to me rules out any driveline issues. It has to be engine/transmission related. And the torque converter is what is going to experience the load. I also have a lot of vibes from 3000 rpms and up, but even under no load in neutral. I'm just at a loss with it, on the edge of selling it.
  11. Jul 31, 2017 at 2:02 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I replaced mine due to a shudder at light throttle acceleration
  12. Jul 13, 2018 at 3:55 PM
    tkvolcom
    tkvolcom New Member
    Tad
    2013 White Tacoma TRD Off-Road
    Total Choas Upper Control Arms, Bilstien 5100, add a leaf in rear. 50" roof light bar, 30" grill light bar, side shot ditch lights, flush bumper mount flood led pods. 33's on 17's.
    Was the shutter seeming to go straight up into the dash and shake the whole dash it self? I am having issues with acceleration at low speed/throttle but not when I punch it, there seems to be no hesitation. If I do encounter the problem then all I have to do is let off the accelerator really quick and then back on and it seems to not have a problem.
    Thanks
