Torque Converter
Discussion in 'Technical Chat' started by cr500taco, Apr 14, 2015.
  1. Apr 14, 2015 at 7:22 PM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    Sounds like I need a new torque converter. Trans temp climbs going up hills and my trans guy thinks it's the TC. Cooling system is fine. What converter do you guys recommend or should I stick with OEM?
  2. Apr 18, 2015 at 6:50 PM
    cr500taco
    D
    Northridge
    4WD
  3. Apr 19, 2015 at 5:48 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Does it over heat or act weird? Tranny temps will climb under load. I watch mine rise and fall on the scan gauge all day. I usually stabilize in stop start traffic at around 190-205. Hop on the hwy and it goes down to 175-185.
