Torque Master Spark Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman04, Jun 16, 2009.
  1. Jun 16, 2009 at 9:20 PM
    tacomaman04
    tacomaman04 [OP] Well-Known Member
    tx
    prerunner SR5
    volant CAI helix throttle body spacer Westin Black Bull Bar Kc Slimlites130watt long range Black out Taillight Mod Flat Black Rims Flat Black Emblems Two 10' Kenwoods 1200Watt Alpine Amp Surround Black grill Flat Black Front and Rear Bumper
  2. Jun 16, 2009 at 11:09 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    How much performance are you expecting from them? It'll probably be minor in a daily driver. Just stick with what came from the factory, Denso or NGK plugs and since you have a V6 make sure you use the dual pronged electrode plugs because it what's recommended/required by Toyota.
  3. Jun 17, 2009 at 4:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2! Most plugs like the ones listed in the link have caused problems in the Toyota engines. Use the OEM plugs for best results.
