Torque on rear u-bolts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by super_white, May 26, 2019.
  1. May 26, 2019 at 12:33 AM
    super_white
    super_white [OP] Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Leafs (OME) and u-bolt flip (wheeler's) are ready to go back in the truck. Once that's done I can do the front.
    The factory torque spec is 37 ft. lbs. Is it the same for aftermarket u-bolts?
    Thank you in advance.
  2. May 26, 2019 at 12:57 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  3. May 26, 2019 at 5:25 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I think the wheeler's instructions call for 90ft lbs, Mine did a few years ago.
    I re-torqued them again 100 miles later and they did loosen up some.
  4. May 26, 2019 at 1:54 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Pretty sure Toyota put out info on this regarding someone reversing the numbers on TIS. I always do 90, recheck later to 100 torquing in a kriss cross X pattern to keep it even
  5. May 26, 2019 at 2:34 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Check them weekly until you know they don't rotate any more. It isn't a one and done or two and done operation. I was surprised. Ended up going to 100.
  6. May 26, 2019 at 3:45 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    When in doubt follow one of many general torque guides. These are max specs, and for dry threads; if you lube with antiseize, or even spit, decrease by 10-15%..
    http://www.dansmc.com/torque_chart.htm
  7. May 26, 2019 at 6:19 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    always done ~ 75 ftlbs on mine.
  8. May 27, 2019 at 3:12 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Right now they are at 73, still have to install the extended brake lines and OR gas tank straps.
    I finally have a use for the trip odometer. A will be for the rear (100 miles) and B will be for the front (500 miles).
  9. May 27, 2019 at 12:16 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Torqued the u-bolts to 73 ft. lbs.
    Did not install the gas tank straps.
  10. May 2, 2020 at 12:09 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I just had my leaf springs replaced by the dealer for a recall. I checked their work after bringing the truck home. They are still torquing the u-bolts to 37 lbs. Some of them had evidently loosened during the 20 mile drive home and were barely about 30. I'm glad the axle stayed on coming home.
