Torque Pro Adapter
Discussion in '1st Gen. Tacomas (1995-2004)' started by old grouch, Jun 24, 2020.
  1. Jun 24, 2020 at 4:46 PM
    old grouch
    old grouch [OP] Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    What adapter are you folks using for your Torque Pro app? Links please. I have bought 2 different ones & both stopped working (on 3 vehicles) within 6 months. Thanks.
  2. Jun 25, 2020 at 10:08 AM
    j4roe
    j4roe Well-Known Member
    Joe
    Phx, AZ
    1st Gen
    Solo Motorsports 3.5 with heimed tubular uppers, Total Chaos spindle gusset, King 8" CO, Glassworks 3'' front glass, tube bumper, 4 25w 1000L Bumper LED, 2 Rigid Pod lights, 35" Toyo Open Country AT, Fiberworx 3'' Bedsides, Deaver F55, Custom 9" Shackle, Bilstein 7100 14" 2.0 smooth body w/resi
  3. Jun 25, 2020 at 10:11 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    After going through several I can tell you the Panlong and similar blue ones for $10-15 dollars don't seem to live too long if they aren't DOA.
  4. Jun 25, 2020 at 6:07 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I have the Bafx one, actually two of them that @j4roe linked to.
    Had them a couple years now and while I don't use them constantly, they still work every time I used them.
    I used to have them running constantly to monitor various temps while driving, but I don't do that as much anymore. They work great. And they're like $20...
  5. Jun 26, 2020 at 6:42 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    That is the latest one to quit working. Pretty sure it is the adapter since it worked before on three vehicles & now doesn't work on the same three vehicles.
  6. Jun 26, 2020 at 7:25 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I have an older version of that and it still works, probably 5 years old. From looking around at them it seems no matter what all of them are hit n miss.
    j4roe likes this.
  7. Jun 27, 2020 at 12:33 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I own two of them. Both work fine.
    j4roe likes this.
  8. Jun 29, 2020 at 6:07 PM
    j4roe
    Joe
    Phx, AZ
    1st Gen
    I use mine on two different cars. The taco and my daily Honda Civic. I have noticed the OBD port on my Civic is a little temperamental. You have to push it in there a little harder for it to make it's connection but 2 years now and zero issues.
    I will give you ONE HEADS UP right now though. After using Torque Pro for EVERY SINGLE drive in either car for two years now, the Torque Pro APP has burned an IMAGE on my GS9 screen... The ideal option what I plan on doing shortly is buying two cheap $70 Android tablets with GPS enabled to basically run a DIGITAL DASH and due away with the stock Toyota dash. Pretty sure a 10" tablet will fit in the gauge cluster and I plan on using velcro to stick the pad straight to the plastic cover over the gauges.
    Madjik_Man likes this.
  9. Jul 5, 2023 at 2:15 PM
    Mavigogun
    Mavigogun Well-Known Member
    1998 Tacoma X-Cab SR 5 2.4L L4 SOHC 16V
    I just installed the BAFX harnessed to Torque Pro; it took about 20 minutes to perform a complete scan while I idled. 27 items populated- all green -with no indication of why the check engine light was on, or why it had been running rough at idle. Is there anything special we need to do for the Tacoma's check engine warning to be recognized? Is there some special setup or code that must be entered?
