Torque Reduction for Anti Seize?
Discussion in 'Technical Chat' started by PaintFadeParade, Aug 23, 2025.
  1. Aug 23, 2025 at 7:08 AM
    PaintFadeParade
    PaintFadeParade [OP] Well-Known Member
    Joe
    CA
    2010 Black Access Cab 2.7 L4
    Anybody know of a good rule of thumb here?
    I've been avoiding using anti seize due to its impact on applied torque and I'm a little concerned I'm going to kick myself in the future when I can't get anything unbolted.
    Do you use anti seize? If so, do you reduce torque values by a specific amount?
    OvrlndBigAl likes this.
  2. Aug 23, 2025 at 8:02 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Generally I mainly use antisieze on stuff that isn't torqued anyway like exhaust fasteners, O2 sensors, and things I know to be problematic with bolts coming out like uncoated bolts threaded deep into aluminum on some water pumps, thermostats, etc.
    Granted we don't have rust issues here.
    I don't use it or recommend using it on torque/safety critical fasteners like brake and suspension (on the body of the bolt maybe if your worried about it seizing in a bushing but never on the threads) hardware and critical engine fasteners.
    PaintFadeParade[OP] likes this.
  3. Aug 23, 2025 at 9:29 AM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Honestly I’ve never been a fan. As a tech I’ve always hated when people slather everything in anti seize. I’m also not a huge fan of thread locking compounds or over using sealants/RTVs. Having worked on cars for almost 20 years in California I was pretty spoiled, nothing ever really rusted or got seized up. Now I work on heavy equipment in Idaho and still don’t deal with much rusted or seized up components. I have all the chemicals I just mentioned on my service truck but rarely use them. It might be different in areas like the rust belt or where things oxidize and so on. A quick google search will reveal a chart for common fluids/chemicals and their affect on torque vs PSI. This is also why using degrees to torque fasteners is more accurate than resistance. Anyway, I wouldn’t use the stuff unless you know of a specific problem are area, like the lower control arm bolts that like to get frozen on our trucks. Other than that I generally put things back how ever the factory assembled it.
  4. Aug 23, 2025 at 9:33 AM
    Bishop84
    Bishop84 Well-Known Member
    It depends.
    If the threads are rough and exposed to elements and already sub optimal. I leave the torque the same. (lug nuts are a good example)
    If its an 02 sensor, spark plug, or any random suspension fastener, by hand. Like @Dm93 mentions.
    People that coat the bolt till its actually wet torque are the bane of my existence. They are idiots.
  5. Aug 23, 2025 at 6:49 PM
    PaintFadeParade
    Joe
    CA
    Ok, good to read all of these responses. I'll stick to the recommended torque specs and leave the anti-seize alone unless a situation specifically requires it. Thanks all!
