Torque spec for 2.7L A/C compressor idler pulley?
Discussion in '4 Cylinder' started by Allen9621, Aug 28, 2011.
  1. Aug 28, 2011 at 11:54 AM
    Allen9621
    Allen9621 [OP] Active Member
    Northern California
    1996 4x4 5-speed
    Readying for a drive belt change, I can't find the torque spec for the 2.7L 3RZFE A/C compressor idler pulley (the one you loosen to adjust the compressor drive belt tension). It ought to be somewhere in the factory manual but I haven't seen it there.
    The PS pump idler pulley is listed as 14 ft-lbs but I'd rather not assume the same for the A/C idler pulley. Thanks, if anyone has that spec.
  2. Aug 28, 2011 at 3:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Aug 28, 2011 at 5:02 PM
    Allen9621
    Northern California
    1996 4x4 5-speed
  4. Aug 28, 2011 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah...I havent downloaded the version for your truck, so Im not sure if its listed or not. I just posted it so you would have it.
