Torque Spec For rear axle drain plugs 1999 tacoma pre runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunner1, Sep 15, 2014.
  1. Sep 15, 2014 at 11:31 AM
    prerunner1
    prerunner1 [OP] Member
    1999 Toyota Tacoma PreRunner
    I have a 1999 toyota tacoma pre runner 2.7 standard cab automatic.
    I want to change the rear axle fluid.
    I need the torque specs for the 2 rear diff drain plugs ?
  2. Sep 15, 2014 at 12:13 PM
    yotanut
    yotanut Well-Known Member
    2022 TRD Pro 6MT
    Here are the torque specs for 2003 Tacoma. Same specs w/ Diff. lock:
    Rear differential (3RZ–FE, 5VZ–FE, w/o Diff. lock)
    Drain plug, Filler plug: 36 ft-lbf
  3. Sep 15, 2014 at 12:42 PM
    prerunner1
    great but mine is a 1999 w/ 2.7 not any of the ones you mentioned.
  4. Sep 15, 2014 at 12:49 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    1998-2000 says 39ft lbs
