torque spec
Discussion in '1st Gen. Tacomas (1995-2004)' started by radcat692000, Dec 4, 2011.
  1. Dec 4, 2011 at 8:53 AM
    radcat692000
    radcat692000 [OP] Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    anybody know the torque specs on the valve covers...installing new gaskets today and need the torque specs (if any) it cant be much the gaskets are rubber and i know over torque them will deform the gasket.
  2. Dec 4, 2011 at 9:40 AM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    tight lol
    they arent large bolts like what 6 mm or 8 mm bolts? id say probly 14 ftpds. just make them snug and all it good, thinkin too hard about it bud
  3. Dec 4, 2011 at 9:45 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    This. 15-20 is probably fine. Watch the gasket, and stop torquing when it just first begins to pooch a tiny bit. That means you've got good pressure on it, but aren't squashin' it so much you open gaps.
  4. Dec 4, 2011 at 10:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    12 lbs-ft. torque
  5. Dec 4, 2011 at 1:49 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I think its 12-15 ft pounds...but when i did mine I didn't have a torque wrench that went that low.
    I did finger tight plus 1/4 turn. Then re-snugged them a week later. No problems so far.
    I did the valve cover gasket a few years ago and overtightened the bolts, so the gasket leaked.
  6. Dec 4, 2011 at 2:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can use a torque wrench that has in./lbs readings. 1 lbs./ft = 12 in./lbs. Many 3/8 torque wrenches are avilible in inch pounds, as are most all 1/4" drive torque wrenches.
