Torque Specs Gen 1 Tacoma Front Crossmember Sub Assembly Bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gen1OldSchool, Mar 9, 2024.
  1. Mar 9, 2024 at 11:25 AM
    Gen1OldSchool
    Gen1OldSchool [OP] Member
    2003 Tacoma Prerunner 2x4 Xtend Cab
    Hi all,
    I've installed a winch mount (from Amp'd Up) for the front of my 2003 Taco, but I cannot for the life of me find the torque specs for the 6 bolts that held in the crossmember (which was removed) that are now holding the winch mount.
    Theres 2 sets on the bottom, which are 17mm bolts with a number 8 on the head (they held the rings which i removed, and the tow hook, and two which held the crossmember on.
  2. Mar 9, 2024 at 5:33 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    17MM are you sure ?? 18mm I never saw a 17mm thread. Did you change Them because mine are M12 x1.25 I just run them up snug like lug nuts
    Area51Runner likes this.
  3. Mar 11, 2024 at 12:34 PM
    Skulking
    Skulking Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    JIS spec M12 would have a 17mm head on it which I'm betting is what is meant by 17mm.
    Per the FSM, a bolt with a 8 on the head is class 8T. Assuming those are 17mm heads and the bolts themselves are M12 flange head as appears to be the case, the standard torque for those bolts in the FSM is 90ft-lbf. It's possible that one of my assumptions regarding the bolts themselves is incorrect, or those bolts for some reason aren't meant to be torqued to the standard specs, but 90 seems reasonable.
  4. Mar 11, 2024 at 12:45 PM
    Gen1OldSchool
    Yes, the head is 17mm. They are not flange bolts however, they have washers. IDK if that makes a difference or not, but figured I'd throw that out there. TY!
  5. Mar 11, 2024 at 7:05 PM
    Skulking
    San Jose, CA
    The standard (No flange) blot torque spec is 80ft-lbf.
