Torque Specs on Rear Springs/Shackle?
Discussion in 'Suspension' started by Sublime, Feb 21, 2012.
  1. Feb 21, 2012 at 4:33 PM
    Sublime
    Sublime [OP] Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Just replaced my sagging/bottoming out old stock springs with new (1,500 miles) ones and added my 3 leaf aal to them. Whats the stock shackle torque specs on these? Also, noticed the shackle angle changes as the trucks raised/lowered. Do I torque these down while the trucks at ride height or doesn't matter as they move around as needed? I just tightened them to 75lbs like the shocks and u-bolts!
    Put my wheelers 3 leaf aal into the new spring pack with overload and got about 3" lift out of it! Rides like it did from the factoy, lol! Waiting for everything to settle before I do final measurements!
  2. Feb 21, 2012 at 4:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Spring mounts, and shackles get 89 ft.- lbs.
  3. Feb 21, 2012 at 4:39 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Don't forget to follow up a few miles down the road and retorque or at least make sure they're not backing out. Do a cross pattern when tightening, similar to that of lugs.
  4. Feb 21, 2012 at 4:41 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    You are the MF'in man Chris! I almost just shot you a PM instead of posting! :thumbsup:
  5. Feb 21, 2012 at 4:42 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Thanks brother!
  6. Feb 21, 2012 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Feb 21, 2012 at 4:46 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    So they're meant to move around based on flex right? So I should tighten them down at ride height?
