Torque Specs
Discussion in 'Suspension' started by Justin626, Oct 5, 2008.
  1. Oct 5, 2008 at 7:55 PM
    Justin626
    Justin626 [OP] Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Has anyone taken the time to look up the torque specs for the u-bolts, leaf spring bolts, bottom spindle bolts, or front shock assembly? It's time to retighten and would feel better knowing what ft/lbs they are suppose to be at.
  2. Oct 5, 2008 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "U" bolts should be 35#
    Cant remember the rest. :eek:
    Just make sure none are loose and you should be fine.
  3. Oct 5, 2008 at 8:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    agreed!
    when we installed the new suspension on my 04....we just tightened everyhting down and even so to speak. when i "retorque" my u-bolts after 100 miles, then 500 miles, i'll torque them to 45 ft. lbs...........thats what wheelers called for on mine.:)
  4. Oct 5, 2008 at 8:01 PM
    Justin626
    Palmer, Alaska
    Damn! No......more......rep!(gasps)
  5. Oct 5, 2008 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL...hit me next time. :D
  6. Oct 5, 2008 at 8:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I wrenched mine to 85# when I installed my AAL. I was haveing a "Blonde" moment. Some of the specs for the Tacoma exceed my Torqe wrench 85# max. so I just give it the "Grrrr" Most times, I just make sure they arnt comming loose. :)
  7. Oct 5, 2008 at 8:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....same way here!!:D
