Torque To Yield Head bolts TTY. Can you re-use them?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, Sep 9, 2022.
  1. Sep 9, 2022 at 3:26 PM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Let this help be a guide in your decision making.
    Factory specs may also have a procedure to test bolt stretch. Not all manufacturers may say the same thing. As always be thorough in your data acquisition.
    https://youtu.be/0b2B6AUzYtw
  2. Sep 9, 2022 at 5:53 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Cool vid, thanks for sharing.
    Torspd[OP] likes this.
  3. Sep 9, 2022 at 6:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is the first video I've seen in a little while that actually really peaked my interest, as I've been re-using TTY bolts for a long time with no found ill results. Interesting data points on the guys behalf. Very thorough and very informative. Great find Tor!
    Torspd[QUOTED][OP] likes this.
  4. Sep 10, 2022 at 4:44 AM
    Torspd
    Tor
    The Great America!
    Aged 625, and vanquish all worry. :D
