Torque Values At Lower Ball Joint & Steering Knuckle
Discussion in '1st Gen. Tacomas (1995-2004)' started by FowlTaco, Nov 4, 2008.
  1. Nov 4, 2008 at 5:57 PM
    FowlTaco
    FowlTaco [OP] Member
    Denton, Texas
    01 PreRunner
    Hey All!
    Having a problem here torquing the 4 bolts at the lower ball joint to the steering knuckle.
    2001 Prerunner.
    The FSM calls for 59ft lbs in at least 3 different places in the manual.
    But at those values I've already snapped one bolt and feels like the same will happen w/the others if I continue.
    I've tried 2 different torque wrenches but they both are identical in torque values in everything I've tested so far.
    So the question is:
    Are these the correct torquing values? It seems a lot for a 10mm diameter bolt.
    Anyone w/experience w/this?
    Thanks!
    -Royce
  2. Nov 4, 2008 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma WOrld!!
    Are you sure the value isnt in inch - lbs.?
  3. Nov 4, 2008 at 6:09 PM
    FowlTaco
    Denton, Texas
    01 PreRunner
    Thanks!
    Well, if it were inch pounds, that would be roughly 5ft lbs.
    I was thinking maybe 30lbs max.
    -Royce
  4. Nov 4, 2008 at 6:25 PM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '09 SR5 AC
    Don't know what the problem is, but a couple things to note: When you never seize bolts, you are actually applying a lot more torque then if the thread were dry. Are the bolts new? Rusted near the head? What grade hardware? A 10mm bolt in grade 8.8 will lift ~3600 lbs, but a grade 12.9 will lift ~12,200, (believe it or not they are strong suckers in tension). I just changed my lower ball joints and used the stock Toyota bolts, I had at least 60 ft.-lbs on them without a problem...but the truck is only 4 years old too (maybe less rust?).
  5. Nov 4, 2008 at 6:34 PM
    FowlTaco
    Denton, Texas
    01 PreRunner
    Appears to be an 11T w/1.25 pitch which would max at 64lbs.
    Used.
    Added just a bit of oil because of light corrosion along the length of bolt.
    Maybe should have left them dry!?
    Never really had a problem w/this before.
    They will click at 40, but any more feels as if they will snap or strip.
    -Royce
  6. Nov 4, 2008 at 6:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think you should use new bolts. Trying to re torque old bolts, I have been told is a bad idea.
  7. Nov 4, 2008 at 6:37 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Um, I torqued down the bottom nut attaching the ball joint of the TC UCAs to the knuckle to between 80-100 #s. Too much?? :eek:
  8. Nov 4, 2008 at 6:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. Specs are 100 ft.-lbs.
    I torqued mine to about 85# and 1 Grrrrrr...
  9. Nov 4, 2008 at 6:43 PM
    FowlTaco
    Denton, Texas
    01 PreRunner
    Upper ball joint 80lbs.
    Lower 103lbs.
    PreRunner and 4WD.
    -Royce
  10. Nov 4, 2008 at 6:43 PM
    LonghornTaco
    Minnesota
    Good! I thought that was the spec... Was about to start worrying about snapping off the bolt.......
  11. Nov 4, 2008 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For stock, yes. Jason and I have TC UCA's. :)
    And I belive those values are for the first gens?
  12. Nov 4, 2008 at 6:54 PM
    FowlTaco
    Denton, Texas
    01 PreRunner
    Ahh! Overlooked that!
    -Royce
