Torque wrench off...thread damage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Dec 13, 2009.
  1. Dec 13, 2009 at 1:10 PM
    JKD
    JKD [OP] Well-Known Member
    I changed my oil yesterday, and when torquing down the drain plug , I felt like I began to feel the threads 'give'. I thought I had the torque wrench set to 30 ft-lbs, but it might have been at 40. I backed off the torque wrench setting, then reset it at 30, loosened and re-tightened the plug.
    Any idea how likely it is that a 10 lb-foot over-tightening of the plug will have done actual damage? Since this is a steel pan, I thought it would be OK, but it sure felt like it began to yield.
    I'm trying to decide whether I should have a new oil pan ready next time I change the oil...
  2. Dec 13, 2009 at 1:20 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    If I had to guess and you din't totally white knuckle the plug in, there was a bit of crud in the threads that you pushed past and once that gave way, it turned easier.
    Oil change shops frequently over torque those - my guess is way in excess of 40 ft/lbs. Hard to explain this move, but if you put a regular ratchet on it, grip it with the ratchet head in your hand (so you can;t get too much leverage) and try it and it doesn't move, my guess is you are fine.
    If it spins or you see metal in the plug threads the next time you pull it, time to do something. They do make self taping oversize plugs if you want to avoid a new pan. Ask at your parts store and they should be able to set you up.
  3. Dec 13, 2009 at 1:21 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Check the threads on the drain plug. Torque wrenches are only for tightening, use a standard rachet or wrench for breaking nuts and bolts loose. The calibration could be off.
  4. Dec 13, 2009 at 1:47 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    The drain plug washer is pretty soft and I'm guessing would take up most of that extra torque. If in doubt, change your oil again though. Last thing you want is that plug to be stripped and loosen enough that you start leaking oil.
  5. Dec 13, 2009 at 1:56 PM
    JKD
    Yes, standard socket or breaker bar for loosening, torque wrench for tightening. Re-used old gasket, which is (as far as I can tell) rubber coated aluminum. Based on its condition it will need to be replaced next time.
    I guess I'll toss a piece of cardboard under the engine and see if I have drips...didn't see anything clinging to the drain plug this morning. I'd rather not have to change out perfectly good Pennzoil Platinum synth...
  6. Dec 13, 2009 at 3:32 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    LOL. Yeah you are the first guy ever to strip a drain plug. :p
    Even if you do booger the thread, it ain't a new oil pan, it's a new plug. Any good parts store will have oversize-threaded plugs for common vehicles. They are sometimes labeled +1
    AND they have oversize oversize-threaded plugs for the next time you booger the thread. Labeled +2.
    Ain't saying how I know, but I swear it's true. :eek:
  7. Dec 14, 2009 at 6:36 AM
    PacoTheTacoMan
    PacoTheTacoMan Well-Known Member
    Weathertechs, personally fabricated tailgate lock, tint, extra D rings, Exactfit seatcovers, re-enforcing the tailgate and adding a leaf next week.
    I really doubt that you pulled threads at 40 foot lbs of torque.
  8. Dec 14, 2009 at 7:04 AM
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    I also doubt 40ftlbs woudl strip the threads.
    ...on a side note I also changed my oil this weekend. I broke out the torque wrench and set it to 30ftlbs. It was not breaking over. I loosen the plug and just hand tightened. Felt better about it. FYI.
    -Al
  9. Dec 14, 2009 at 8:21 AM
    rachunter
    rachunter Well-Known Member
    West Virginia
    08 TRD Off-Road
    XM Radio,Access Lorado Tonneau, Ventshades, Tinted Windows, Destination A/T's , Moto Metal wheels and lots of Liquid Glass
    I just use a ratchet with a short extension on it to tighten the plug that makes it very hard to overtighten.
    It is not necessary to torque the drain plug, it just needs to be good and snug. If your torque wrench messes up or you have it set wrong with all of that leverage (length of torque wrench) it is very very easy to mess up the drain plug or even worse the oil pan.
  10. Dec 14, 2009 at 8:25 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    When torquing such sensitive drain bolts and spark plugs I usually switch over to a torque wrench that measures in inch pounds, I find them more accurate at such low torque values. Some of the ft/lbs torque wrenches aren't too accurate at such low values - especially the ones that their scale don't start until 20 ft lbs or so.
    To use inch pounds, take your ft/lbs value and multiply by 12.
    Example: 30 ft/lbs * 12 = 360 in/lbs
    Maybe a little OCD, but it hasn't failed me yet.
  11. Dec 14, 2009 at 8:40 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If there is a torque value and you know how to use a torque wrench...You can't really mess it up.
    And on the same note- If they give a torque value and have the means to use it- Why wouldn't you??
    A few folks have mentioned the +1 self tapping drain plugs- They are there for a reason- When folks just tighten them without checking what they are doing- Need a way to fix it.
  12. Dec 14, 2009 at 9:39 AM
    rachunter
    West Virginia
    08 TRD Off-Road
    That is exactly the point I was trying to make. You cannot overtighten using a rachet and a short extension, even if you try. If your torque wrench if not accurate, set wrong or just malfunctions you will mess up the threads because of the leverage the length of the torque wrench gives you.
    I really appreciate trying to do things right but putting a drain plug in is not rocket science.
    At least that has been my experience in my 30 plus years of working on cars, trucks, tractors, race cars, motorcycles and atv's.
  13. Dec 14, 2009 at 10:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Hmm... I've never used a torque wrench on an oil drain plug. I always just tighten it and I never put any grunt into it. Never had any problems.
    If you believe you have a problem with the threads... get yourself a TAP of the proper size. Run the tap through it and it'll clean out the good threads and cut any burrs that might exist on the old/bad threads.
    I highly doubt that torque difference messed the threads up.
  14. Dec 14, 2009 at 11:44 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    same here...
  15. Dec 14, 2009 at 1:01 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This is the prime example of complacency- Your 30 years plus is great empirical evidence for your method...Until something does go wrong. THings still fail even if you torque them down properly- but if you do torque/set them properly...you know it's not install error that caused the failure.
    It might not be rocket science- but the one time that a drain plug falls out- It'll most likely cost you a few grand- I'd rather spend the 5 mins to make sure I have a calibrated, correctly set torque wrench than 4-5K.
    It's your truck...Do what ever you want.
  16. Dec 14, 2009 at 1:48 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    I'm in the 30 year crowd too. What if the threads are already on the way out? Recommended torque could ruin them. I'll stick with Jansters method.
    I haven't lost one yet but I've seen some pretty buggered up ones.
  17. Dec 14, 2009 at 2:14 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    torque wrench on the drain plug? i just do it with my regular ratchet..snug it up..good. done.
    i dont use it on spark plugs either.
  18. Dec 14, 2009 at 2:16 PM
    Janster
    Jandy
    Lancaster, PA
    I'm not an auto mechanic but I am a machine operator by trade...so I've put in a few nuts/bolts over the years.
    There's a lot to be said about the *FEEL* of putting a bolt into threaded hole. Not everyone knows what to FEEL for. If something doesn't feel right or you get 'resistance' going in - then your gutt reaction should tell you to STOP threading it in further. Remove and inspect.
    Some people keep going torqueing....and if you don't stop soon enough, you can bitch up the threads.
    One of the main reasons why I don't use torque wrenches initially ...is so I can FEEL the bolt thread into the hole. I like to FEEL things go in smoothly before I torque on them.
    THis stuff isn't necessarily something newer or inexperienced people are gonna know to look for.....
  19. Dec 14, 2009 at 2:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Concur with an initial hand threading- Plus it goes more efficiently that way. Only the last few turns need any sort of tool.
  20. Dec 14, 2009 at 3:44 PM
    JKD
    I know you don't know me from Adam, but I'm no beginner at this. I've been turning my own wrenches for about 20 years. The plug was not cross-threaded, it spun in fine by hand until finger tight, and then i used the torque wrench. (When I have a torque spec, I prefer to use it. Estimating using a plain ratchet is for emergency repairs on the side of the road, or tightening fasteners that are no where near their yield limits.)
    The engraved marks on my torque wrench are a little hard to distinguish, and it was late at night. I stopped turning shortly beyond where it should have clicked for 30 foot pounds; at worst, it went to 35 or so.
    Well, we'll see if there's any apparent damage in about two months when it's time to change the oil again. If it won't seat well at 30 foot pounds, or pulls the threads out...I'll know I screwed it up. :)
