Torque wrench suggestions
Discussion in 'Garage / Workshop' started by Pster, Jul 19, 2009.
  1. Jul 19, 2009 at 9:23 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I need to get a torque wrench. Can annyone recommend a good one for ~$100? Do you set them to the desired ft/lb and then they break tension when they get to they pre-set torque?
  2. Jul 19, 2009 at 10:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think Craftsman has a good one for about $70.00 or so. Yes, You set the torque, and it will cklick when it is achieved. :)
  3. Jul 19, 2009 at 10:33 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    craftsman should be a decent one. i got lucky acouple years ago and scored a snap on 1/2" drive wrench. guy traded it in on a new one, i bought it for $100 and the snap on guy did a rebuild on it for free... plus he calibrates it whenever i ask for free... can't beat that!
  4. Jul 19, 2009 at 10:42 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    My craftsman torque wrench has provided me with years of service. Only issue is I think it only goes up to 100 ft/lbs but I rarely have anything I need to torque that exceeds that.
  5. Jul 19, 2009 at 10:49 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I bought a husky at Home depot for like $60. Works well.
    Only does 100FtLbs.
  6. Jul 19, 2009 at 11:15 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Is there an optimal length on these? I have seen some that look sorta short for torquing down lug nuts. The ft/lbs for lugs is ~80lbs????
  7. Jul 19, 2009 at 11:38 AM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i hvae the craftsman digital.. its amazing. AND since its a craftsman, if it breaks it will be replaced. Even though theyre a bit more expensive, i believe craftsman is the way to go for quality and warranty.
    (Ive brought a 1/2 inch wrench in broken, said "I used it as a hammer and it broke" and they gave me a new one...)
  8. Jul 19, 2009 at 11:44 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks, I am going to SEars online now to research....
  9. Jul 19, 2009 at 11:49 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Wow, the SEARS electronic is pricey at $260.......ouch. I have a hard time thinking its $150 better than the click type at $105??
  10. Jul 19, 2009 at 12:01 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    search ebay. I just got a nearly new, 200 ft lb 1/2" snap on torque wrench for $92 shipped. And since its snap on, its warrentied for life and as stated before, the snap on guy will calibrate it when ever I need it. I prefer the long style also, you can get more torque on what ever your working on also.
  11. Jul 19, 2009 at 12:22 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yep, looking at Ebay as you wrote this! Thanks! Would you recommend 1/2" ver 3/8". I suspect so as I will be using mine primarily for lug nuts.
  12. Jul 19, 2009 at 12:26 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    thats all I wanted one really. i got 1/2" for lug nuts. i dont think 3/8'' goes up that high. I remember I had an old craftsman one, and it went to like 90lbs. Not enough for lug nuts.
  13. Jul 19, 2009 at 1:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    We have Craftsman 1/2" and 3/8 torque wrenches. They've never failed us.
    Just a tip - don't forget to put the torque wrenches back to ZERO when you're finished. This helps prolong the life of the mechanism.
  14. Jul 19, 2009 at 1:23 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Thanks! I am going to bid on a SEARS wrench on Ebay today.....:)
  15. Jul 19, 2009 at 1:25 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I usually dont do the bidding thing, i dont have the patience:rolleyes: im all about the buy it now option:D
  16. Jul 19, 2009 at 1:33 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I snipe. I bid with 2 seconds left, and I NEVER LOSE. :D I HATE and LOATH stores. I would rather you cut both hands off than go to a mall. The ONLY stores I frequent are Lowes, HD, and hardware stores. The rest are totally USELESS.
  17. Jul 19, 2009 at 7:38 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Got it refurbished. OoO yah
  18. Jul 19, 2009 at 7:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i got a half inch drive "great neck" torque wrench at autozone for about $25 or so........and it works great...........torques the same as a more expensive one i got a napa a few years ago.
  19. Jul 20, 2009 at 3:19 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    x2
    Also, don't loan it out to anyone! Even family! I loaned my $150 wrench to my bro-in-law and now I have to replace it. Damn gorilla.
  20. Jul 24, 2009 at 4:56 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Just found this on Car Talk.....Click and Clack's take on used torque wrenches:
    Dear Tom and Ray:
    My father taught me a lot about cars by having me do the work while he "supervised." I don't remember how old I was, maybe 8 or 10, but I was young enough that I had to stand on a crate to reach over the hood to the engine. The lesson of the day was how to change spark plugs in the old family Chevy. I was determined to show my dad how "big and strong" I was, so I cranked on the plug probably more than he thought I could at my young age. As he was standing there smoking his pipe and watching, I snapped that baby off in the block. He never yelled, just kept looking at the engine, and finally said, "Run in and tell your mother we'll be a little late for dinner." That started the next lesson, on how to use a torque wrench (he spared me the task of extracting the old plug and fixing what I had done). I am now 53 years old, my dad is long gone, and I still have the torque wrenches of my dad's that I made sure I got when he passed. They have been treated with respect, and are both the "bar" type and the "clicking" adjustable type. Can I still trust them? Is there any way to check or calibrate them? I still get emotional every time I use them, remembering my dad and the many automotive lessons he taught me. But I know he would be upset to learn that I was using a tool that was no longer fit for the job. Thanks for any advice you can offer. -- Jim
    TOM: Your dad sounds like a wonderful, patient man, Jim. My dad was like that, too -- until my brother came along.
    RAY: You have two different types of torque wrenches, Jim. The old "bar and pointer" type were never extremely accurate. But the good news is that they almost never went out of calibration from where they started. And they're good enough for most automotive work. So I think you can continue to use those for things like spark plugs and wheel nuts.
    TOM: Right. If you were writing to us about working on your Exelon pressurized water nuclear reactor, we might be concerned. But your bar-and-pointer-style torque wrenches probably are still fine.
    RAY: The "click" type are more accurate, but they can go out of calibration over time. Those should be recalibrated if you're doing any kind of precise work.
    TOM: If you go online and search on Google for "torque wrench calibration," you'll find a number of labs that you can send your wrenches to. They'll recalibrate them and send them back to you.
    RAY: There are even some that will come to your house or place of business and do the calibration on the spot. And since your wrenches are irreplaceable and have great sentimental value, you might want to do that, rather than take the chance of having them get lost in transit somewhere.
    TOM: You also can ask at a good local auto-parts store. They may have somebody nearby whom they recommend. Then you can stand over him, and make sure he doesn't mess with Dad's torque wrenches. Good luck, Jim.
