Torque wrenches
Discussion in 'Technical Chat' started by Bennoclarke, Jan 25, 2016.
  1. May 18, 2019 at 11:14 AM
    #41
    eon_blue
    Azusa, CA
    I have the Tekton one mentioned on pg 1 I got on Amazon for ~$40, I use it quite a bit. Also have the smaller 20 -150ft lb Harbor Freight one, I'm just a shadetree DIY'er but they both have served me well.
  2. May 19, 2019 at 8:29 PM
    #42
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    FYI. believe it or not, after a while a torque wrench will not give the proper torque. I work in the Aviation industry and we use Snap-on for most of our tool needs. A Snap-on Torque Wrench is roughly +-4% accurate from the factory. After use, possibly a dingbat dropping the TQ wrench or mishandling it can cause it to be further out of cal. I've seen some get to +-10 percent. I wont use one if it's over 6%.
    Take it however you want but think about how accurate is the TQ wrench you are using. Be mindful. Cheaper ones may not be as accurate as you may think causing you to over or under torque something.
  3. May 19, 2019 at 9:34 PM
    #43
    razhick4x4
    razhick4x4 Well-Known Member
    Alex
    MT/WY
    2004, Tacoma SR5 Xtracab TRD, 4x4, Red, 5spd. V6
    ARB Bumper, 3" Toytec/OME lift, 33s, Sliders, ARE Topper, Ditch Lights, Hella LEDs, Trigger controller, CB, Pioneer Radio
    this pretty much sums up my opinion on cheap torque wrenches. on a side note, after posting i went out to my shop to look at my HF torque wrench again and, funnily enough, it wouldn't work when i pulled it out of the case. it just wont click, even when i know that i am putting well over 50 ftlbs of torque on my test nut. wasn't dropped or anything. oh well, looks like i'll be taking a trip to the "hazard fraught" to take advantage of the warranty. take it however you want but i can say that i probobly wont be purchasing another one of their tq wrenches.
  4. May 20, 2019 at 3:33 AM
    #44
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    FWIW, I wouldn't expect any professional technician to be caught with a H/F torque wrench as their go to tool. Let alone the aviation industry being a whole different level of precision above all.
    I deliver (retirement job) to pro shops (light & some heavy repair) all day long. I can tell you the lowest guy on the totem pole most likely has a Snap-On or Matco (or better) in his box.
    HF stuff was never marketed for, or meant to be professional level tools.
    TheDevilYouLove likes this.
  5. Jun 19, 2019 at 9:38 PM
    #45
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I have two craftsman 1/2” torque wrenches that are 20 years old. They are used, then returned to no load and stored. Also have a 3/8” HF one that is maybe 10 years old and handled the same way.
    Have done lots of work on my vehicles using them, including valve jobs on my Ducati, complete teardown and rebuild on V65 Magna, valve jobs on S2000, valve job and timing belt on a few Acura’s, and more. I’m good with +/- 10% accuracy... and never had any issues with breaking or stripping fasteners or them coming loose.
  6. Jul 17, 2019 at 10:11 PM
    #46
    NavyGuyAN
    NavyGuyAN Well-Known Member
    Virginia Beach, VA
    2010 Silver Taco 4x4
    Wet Okole Seat covers, Weathertech Floor mats, Blistein 5100's all-around, BFG KO2’s Fumoto Drain valve
    I have the Tekton 25-250ft.lbs. torque wrench. LoL. works for mostly all applications on the truck. But if you ever end up changing your front wheel bearing assemblies you will need something that goes past the required 273ft.lbs. required for the axle nut torque.
  7. Jul 18, 2019 at 4:15 AM
    #47
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I got a used Snap-On click type. $100, love it!
  8. Jul 18, 2019 at 10:01 AM
    #48
    eon_blue
    Azusa, CA
    I have that one and love(d) it, but one day I was being too quick with adjusting it and the bottom piece fell off and the little pins inside fell out with it. Never could find them, not sure how important they were but I don't trust it to be accurate now. Luckily it was cheap on Amazon so I'll just grab another.
  9. Jul 21, 2019 at 7:13 PM
    #49
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    I have the HF torque wrench. It has served its purpose. A year ago, or so, I suspected it may be out of calibration so I sent it Micro Precision Calibration in Grass Valley, CA for testing. Micro Precision tested it, found it to be within spec and certified it as such. I spent more on the calibration testing than on the wrench itself, but I just had to know.
    YMMV.
    Nitro52 and underaroof like this.
  10. Jul 28, 2019 at 2:18 PM
    #50
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Was reading your post and thought, there must be a way to test my torque wrench and see if it's within spec.
    Sure enough:
    https://www.tekton.com/torque-wrench-accuracy-and-calibration
    However, sounds like I still need to send to a professional calibration lab if I want it tested and recalibrated if necessary.
  11. Jul 28, 2019 at 2:30 PM
    #51
    mcm808
    mcm808 Well-Known Member
    Micah
    Kane’ohe, O’ahu
    3rd gen
    I love absolute red! I had an auburn sky pearl 01 is300 and loved it. Going to mod it? I lowered mine quite about 2 inches and loved the look. put on some bhlm and some aftermarket tails so they weren't all chrome...those cars are tanks!
  12. Jul 31, 2019 at 5:21 AM
    #52
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    +1 for the CDI endorsement.
    I have a 3/8 drive - I think the range is 7-75 and a 1/2 that goes from 50 to 250 (or something along these lines).
    Figure I have most automotive torque needs covered.
    I think it was $330 for both when I got them. A bit pricey but not over the top...
  13. Jul 31, 2019 at 6:20 AM
    #53
    Tylerh147
    Tylerh147 Well-Known Member
    Tyler
    Chattanooga, Tennessee
    2007 DCSB TRD OR 4x4
    5100s, 885s, Icon AAL
    wi_taco likes this.
  14. Jul 31, 2019 at 9:22 AM
    #54
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Yeah, I have three covering a wide range and thus a bit of money invested but I love them. I'd like a smaller one for gunsmithing. Maybe the 5-40 in/lb screwdriver type. But it's $145 for not that much use...
    3/8" 30-250 in/lb (valve cover bolts)
    3/8" 10-100 ft/lb (most bolts, including wheel nuts)
    1/2" 30-250 ft/lb (Large suspension bolts) I use this for wheel nuts because of the additional leverage for 80 ft/lb.
    PzTank[QUOTED] likes this.
  15. Sep 10, 2019 at 3:12 AM
    #55
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I'm happy with my 1/2" 250 ft/lb CDI, (Snap-On) that I've had for years.
  16. Sep 11, 2019 at 11:54 AM
    #56
    TheDevilYouLove
    Marylandistan
    I just got a Quinn 3/8" drive torque wrench from Harbor Freight. So far, so good! Should be perfect for spark plugs and general auto stuff. It does 5-100 foot/pounds.
  17. Sep 21, 2019 at 7:50 AM
    #57
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    I used a HF torque wrench for about two years until it broke internally. Who knows how far off the calibration was at that point. It was the most frustrating tool I've recently owned.
    I went ahead and bought two (one for in/lbs, one for ft/lbs) eTork wrenches. Couldn't be happier!
  18. Oct 22, 2021 at 3:47 PM
    #58
    manfred twd
    manfred twd Active Member
    mike
    2021 trd takoma
    I went to harbor freight yesterday. I need a wrench to torque my oil canister to 18 ft lbs and they had none that went that low.
  19. Oct 22, 2021 at 3:49 PM
    #59
    eon_blue
    Azusa, CA
    They have them online, maybe it wasn't in stock at that store.
  20. Oct 22, 2021 at 4:16 PM
    #60
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    You’ll likely get more use from an in/lb wrench. Most torque wrenches are more accurate in the middle and top of their ranges anyway. When you get into the lower ft/lb just go with a smaller wrench. They are good for spark plugs and valve cover bolts and drain plugs. All kinds of stuff.
    I use my 3/8” 20-250 in/lb wrench more than my big 30-250 and even my 10-100 ft/lb ones.
    06Tacooo likes this.
