Torque wrenches
Discussion in 'Technical Chat' started by Bennoclarke, Jan 25, 2016.
  1. Oct 22, 2021 at 4:29 PM
    #61
    manfred twd
    manfred twd Active Member
    mike
    2021 trd takoma
    thanks for the replies , I found the one I wanted not far from my house and started the order but shipping was about $7 and I go there every week or so. Ill just hope it's still there when I go
  2. Oct 24, 2021 at 11:51 PM
    #62
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    ‘ needle gauge ‘ wrenches are the most accurate..................also the most fragile
    can be returned on a regular basis to be recalibrated
    ‘ needle gauge ‘ the ONLY way to fly with inch pounds !!
    ‘ clickers ‘ offer a false sense o security
    can be out both ways yet NO Way to tell...............can also be recalibrated
    yet to KNOW NOT When !!
    ‘ bar ‘ type are good for rough work whereby a few pounds over might NOT strip a bolt
    ALL should be protected in a case not wallowing /floating around a tool chest
    i have ALL 3 & only take 1 out when neccesary & Replace immediately after use !!
  3. Oct 27, 2021 at 8:43 PM
    #63
    Steve-O
    Steve-O Well-Known Member
    SW Ohio
    2007 Tacoma 4x4, TRD Off-Road
    I have and recommend the 20-100 ft-lb version: https://www.amazon.com/Precision-In...rench-Torque/dp/B000YOX568?pd_rd_i=B000YOX568
    Of all my torque wrenches, I reach for this one the most. I've thought about getting its bigger brother, but I rarely need to torque anything over 100 ft-lbs.
    The nice thing about the split beam torque wrenches is that you don't have to zero them out after every use. I just put it back in my tool box and set it to whatever I'm working on when I need it again.
    I trusted it enough to install this in one of my other vehicles:
    Not that it is an indicator of quality, but I abuse the living hell out of that clutch at the drag strip, so you better believe I pay very close attention to all torque specs when installing it, which I've done twice now (long story).
  4. Jan 6, 2022 at 8:35 PM
    #64
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    Any recommendations for a shorter handle 1/4" or 3/8" torque wrench for tighter access DIY such as spark lugs, oil change, etc? Important factor is not to be terribly expensive.
    Klutch (Northern Tool) has a 3/8" 5-80 ft-lb unit at 14" long...
    https://www.northerntool.com/shop/tools/product_200621084_200621084
    I have an 18" 1/2" 10-150 ft-lb Pittsburgh Pro that I carry in the truck for lug nuts.
  5. Jan 6, 2022 at 8:53 PM
    #65
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I have a few. I got this dewalt that I got for pretty cheap. I was inspired even more when i saw project farm do a torque wrench video and the Dewalt did pretty good. I used a torque meter to 83 ft lbs last I time I did wheels and tires, and it was right in there.
    i also have a tekton in 3/8s (non split beam) that I’ve used for a while. It’s been good enough for the weekend.
    Area51Runner likes this.
  6. Jan 6, 2022 at 9:18 PM
    #66
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    For smaller stuff I have a CDI 30-250 in/lb in a 3/8 drive. It gets a lot of use. The 10-100 gets less and the 30-250 gets the most. Longer for easier use than the 10-100.
    They’re all CDI.
  7. Jan 6, 2022 at 9:23 PM
    #67
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I have a craftsman lb/ft and another lb/in wrench. I figured out how to calibrate them on my own. They are not the quality NASA would use but work very well. They hold the calibration.
    IMPORTANT: always back them back to the lowest setting before storage. It keeps the measurement spring accurate.
  8. Jan 6, 2022 at 9:39 PM
    #68
    2pei
    2pei Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    I'll wager thay had one that went to 216 in/lbs
    skeletron likes this.
  9. Jan 7, 2022 at 5:17 PM
    #69
    IL14TacoGrey
    IL14TacoGrey Well-Known Member
    2014 Grey Tacoma SR5
    I like the Armstrong 64-064N, you can get it on eBay for a very good price.
    #69
  10. Jan 16, 2022 at 11:10 AM
    #70
    Retumbo7
    Retumbo7 Well-Known Member
    SF Bay Area
    I personally use SK Torque Wrenches. They are not cheap, however they are produced in the same factory as the Snap On ones at a fraction of the price. They come with a calibration sheet, and it's easy to send them off to get re-calibrated if necessary.
    I also have cheapo Taiwan Torque Wrenches, and there is consistently a 10%+ difference (especially at the loosest setting) with the SK ones. 10% isn't that dramatic when you're talking 100+ ft-lbs, however it does matter with smaller bolts (especially on motorcycles).
  11. Jan 28, 2022 at 9:58 PM
    #71
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I live 8 blocks away from Snap-On headquarters. If I wrenched for a living I would own one. Can’t justify $$$$ as a “hobbyist”.
    Almost bought a CDI but couldn’t get my hands on the one I wanted during pandemic.
    Bought a Precision Instruments. Come to find out they aren’t too far away in Illinois. So far so good, checked accuracy and it’s within spec.
    Have some old HF and Crapsman bought when I was young and poor. Don’t trust them and only use when clearance is an issue because they have super short handles. More calibrated than my hand/brain torque meter, better than nothing in a pinch.
