torque
Discussion in 'Suspension' started by taco_man, Dec 15, 2010.
  1. Dec 15, 2010 at 7:34 PM
    taco_man
    taco_man [OP] Well-Known Member
    Austin
    Houston
    09 texas edition
    Borla exhaust, K&N intake, Full sound system
    whats the torque of the bolt going from the lower control arm to the frame.
    Also the torque of the nut that is on the bottom of the lower a arm. the one that pivots.
    yes i know there is a torque sheet out there but i want to make sure im getting the right torque specs because im not so sure on all my suspension terminology.
  2. Dec 15, 2010 at 7:37 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Also the torque of the nut that is on the bottom of the lower a arm. the one that pivots.-called the lower ball joint and it's 103 ft/lbs
    bolt going from the lower control arm to the frame-100 ft/lbs
    I think this is what you are talking about. If you have pics with the parts circled it would be better. Confusion here isn't the best place.
