Torquing UCA long bolt help
Discussion in 'Suspension' started by Mwhres145, Nov 30, 2022.
  1. Nov 30, 2022 at 5:52 PM
    Mwhres145
    Mwhres145 [OP] Well-Known Member
    2015 Tacoma
    Does anyone have any tips on properly torquing your UCA long bolt to spec while truck is on the ground in the proper position? Short on clearance between fender and tire. If I am not mistaken it needs to be in its ride height position for proper articulation?
  2. Nov 30, 2022 at 5:54 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, I just double wrench, or use a really long wrench it while its sitting as tight as I can go, then again after test driving.
  3. Nov 30, 2022 at 6:14 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Jack under the lca enough to take the truck off the stand under the frame. Then torque.
    eurowner and reallifedog like this.
  4. Nov 30, 2022 at 6:33 PM
    Mwhres145
    2015 Tacoma
    The clearance prevents the torque wrench or any wrench from resetting the ratcheting mechanism, even if I add a cheater bar/extension it doesn’t do me any good. If that makes sense?
  5. Nov 30, 2022 at 6:33 PM
    Mwhres145
    2015 Tacoma
    Good idea thanks
  6. Nov 30, 2022 at 6:38 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I use a crows foot to get around this.
  7. Dec 2, 2022 at 9:25 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    It can help to turn the wheels to full lock. You'll gain a slight bit of clearance.
    reallifedog likes this.
  8. Dec 2, 2022 at 9:31 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I'm able to do it with wheels on the ground, but this idea above should get the OP close enough.
    85 ft lb for the UCA bolt.
    airmax233, reallifedog and TnShooter like this.
  9. Dec 3, 2022 at 6:05 AM
    Mwhres145
    2015 Tacoma
    Thanks!
