Torx screw on tailgate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vincent05, Aug 13, 2013.
  1. Aug 13, 2013 at 11:22 AM
    Vincent05
    Vincent05 [OP] Well-Known Member
    Bucks County, PA
    Tacoma
    Anyone have trouble taking the screw off? It seems so hard and I don't want to mess it up.
  2. Aug 13, 2013 at 11:23 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Looks like they are stripped already.
  3. Aug 13, 2013 at 11:25 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    yup. That is one stripped out screwhead. Definitely gonna have to drill that out at this point. Or you can try cutting the outside of the head into a square and getting some pliers on it.
    Or leave it alone :D
  4. Aug 13, 2013 at 11:30 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I would cut a slot across it and use a flat head Screwdriver.
  5. Aug 13, 2013 at 11:33 AM
    Anteupp
    Anteupp Mega Member
    buy new bolts, and invest in some of these.
  6. Aug 13, 2013 at 11:33 AM
    VolcomTacoma
    Jeff
    NorCal
    AH yes, ^ this works as well. I went straight to the last resort :D
  7. Aug 13, 2013 at 11:33 AM
    Vincent05
    Bucks County, PA
    Tacoma
    Looks strip but the torx can fit in there and I don't want to strip it anymore. Thinking of going to dealer to remove and replace it as a last resort.
  8. Aug 13, 2013 at 11:35 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    That should not be the last resort in this case. I have faith in you. If the socket fits turn it. If it gets screwed up use one of our methods and get a new bolt to replace them.
  9. Aug 13, 2013 at 11:39 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Back it out with a socket wrench as opposed to drill to avoid further stripping.
  10. Aug 13, 2013 at 11:42 AM
    Vincent05
    Bucks County, PA
    Tacoma
    Forgot to mention I'm trying to install the EZ down tailgate. Need to place a bracket there. Another option is to leave that alone and drill another hole beside that to mount the bracket.
    tato187carlos likes this.
  11. Aug 13, 2013 at 1:21 PM
    ezatnova
    ezatnova Artax
    West Chester, PA
    21 DC TRD OR - Voodoo
    Wildpeak 265/75/16, Headstrong Progressive AAL, 5100's w Emu 885s
    +1
    This is the best first attempt. Just buzz it with a cutoff wheel and make a nice flat line to use a screwdriver on.
    Happened to me on that same screw. It was in there and wouldn't budge...just stripped out with the torx bits
  12. Aug 13, 2013 at 1:28 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
  13. Aug 13, 2013 at 1:35 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I had trouble removing these when i did the easy down tailgate mod........all i had to do was push in and unscrew......i stripped mine pretty good but i got it out without drilling or cutting
  14. Aug 13, 2013 at 2:17 PM
    Vincent05
    Bucks County, PA
    Tacoma
    Thanks guys finally got it out.
  15. Sep 26, 2014 at 7:00 PM
    MilkmanCDN
    MilkmanCDN Member
    Hey Vincent,
    How did you finally get it out? Brute force?
  16. Sep 26, 2014 at 8:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
